Rosewood drive, media cache and LED:0x000000BD FAddr:0x0000599A problem
SLAB_TEAM0
Postby SLAB_TEAM0 » 13.08.20, 16:58
Hi everyone,
some problems with a rosewood drive and, i suppose, media cache related problems.
This is a ST1000LM035-1RK172 drive.
When it come to us was unable to read ID. After unlocking procedure ID became fully read but terminal showed led problem:
Boot 0x80M
Tech Unlock Handshake: 0xA67DB935
Reply:
QB
Rst 0x80M
Srv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
(POR) Recover Secondary MCMT Opened Recovered
MSP213
(MC POR Duration): 00000000E2
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
PowerState = IDLE1
VC0
PowerState = IDLE1
VC0
(DOS) File Save Wrst Ct: 0000 SU: FFFFFFFF NT: 00000000 OT: 00000000
HighPowerMode
XI2
VC1
VC2Up:Status 0001 Req 0002
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
XI2Status 0001 Req 0038ACTIVE
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
HighPowerMode
VC1
VC2Up:
XI2Status 0001 Req 0002
PrgF
I had to press ctrl+z several times anyway to enter in T level and not always this is successfull.
SA Backup (0+1) was fully performed and all modules are ok
93 module was downloaded and unticked in all checkbox but "media chache" (leaving it checked)
After this I can read, just 1 sector from all user area. At second lba read hdd become busy and terminal start showing again same LED problem written before
To read another sector i need to reboot on/off and to reload all resources from disk after unlocking again.
I followed 348, 2b, 28, 35 system files rewrite from backuped resources without problem but reading user area problems are the same.
As adviced from ACE technicians, I haven't perform anything on traslator even because performing V4 and V40 commands I got entries:
F3 T>V4
Reassigned Sectors List Enabled
Entries: 01E0, Alts: 01DF, Removed: 001C,
Pending: 0004, Host Pending: 0010, Max RSL Size: 00002000
Idx LBA PBA LLLCHS of LBA Wdg PLPCHS of PBA SFI Hours Msecs Status BBM Mask
0000 00000239FF7F 000002EFA846 00F23D.1.0000 07C 0104DF.1.0000 06BD5B ----- ------ 00000021 00000000
0001 00000239FFEC 00000EB6A683 00F23D.1.FFFF 0E2 061F37.1.0014 024C2F ----- ------ 00022010 11111111
0002 0000031F3489 00000EB6A855 013E61.1.FFFF 0CB 061F39.1.005C 07AF53 ----- ------ 00002010 11111111
0003 0000031F348A 00000EB6A856 013E61.1.FFFF 0CC 061F39.1.005D 07BCAD ----- ------ 00002010 11111111
0004 0000031F34F0 00000EB6A857 013E61.1.FFFF 12F 061F39.1.005E 07CA07 ----- ------ 00002010 11111111
0005 0000031F354F 00000EB6A858 013E62.1.FFFF 032 061F39.1.005F 07D761 ----- ------ 00022010 11111111
0006 0000031F3550 00000EB6A859 013E62.1.FFFF 033 061F39.1.0060 07E4C1 ----- ------ 00022010 11111111
0007 0000031F3551 00000EB6A85A 013E62.1.FFFF 034 061F39.1.0061 07F1DB ----- ------ 00022000 11111111
0008 0000031F3552 00000EB6A85B 013E62.1.FFFF 035 061F39.1.0062 07FF35 ----- ------ 00022000 11111111
0009 0000031F3553 00000EB6A85D 013E62.1.FFFF 036 061F39.1.0064 0819E9 ----- ------ 00022000 11111111
000A 0000031F3554 00000EB6A85E 013E62.1.FFFF 037 061F39.1.0065 082743 ----- ------ 00022000 11111111
000B 0000031F3555 00000EB6A85C 013E62.1.FFFF 038 061F39.1.0063 080C8F ----- ------ 00022000 11111111
000C 0000031F3556 00000EB6A85F 013E62.1.FFFF 039 061F39.1.0066 08349D ----- ------ 00022000 11111111
000D 0000031F35EF 00000EB6A860 013E62.1.FFFF 0CD 061F39.1.0067 0841F7 ----- ------ 00022000 11111111
000E 0000031F35F0 000003D61113 013E62.1.00A2 0CE 015104.1.00A2 0AF04A ----- ------ 00000021 00000000
000F 00000578E47D 00000EB6A862 01E83D.0.FFFF 072 061F39.1.0069 085CAB ----- ------ 00002000 11111111
0010 00000BA76546 00000EB6A866 04A9C4.1.FFFF 037 061F39.1.006D 0891D3 ----- ------ 00002000 11111111
0011 00000CD12647 00000EB6A840 055867.1.FFFF 032 061F39.1.0047 069771 ----- ------ 00002010 11111111
0012 00000CD12648 00000EB6A841 055867.1.FFFF 034 061F39.1.0048 06A4CB ----- ------ 00002010 11111111
0013 00000CD12649 00000EB6A842 055867.1.FFFF 036 061F39.1.0049 06B225 ----- ------ 00002010 11111111
0014 00000CD1264A 00000EB6A843 055867.1.FFFF 037 061F39.1.004A 06BF7F ----- ------ 00002010 11111111
0015 00000CD1264B 00000EB6A844 055867.1.FFFF 039 061F39.1.004B 06CC99 ----- ------ 00002010 11111111
0016 00000CD1458B 00000EB6A869 055843.1.FFFF 053 061F39.1.0070 08B9E1 ----- ------ 00002000 11111111
0017 00000CD1458C 00000EB6A86A 055843.1.FFFF 054 061F39.1.0071 08C73B ----- ------ 00002000 11111111
0018 00000CD14590 00000EB6A86B 055843.1.FFFF 05B 061F39.1.0072 08D495 ----- ------ 00002000 11111111
0019 00000CD14591 00000EB6A86C 055843.1.FFFF 05D 061F39.1.0073 08E1EF ----- ------ 00002000 11111111
001A 00000CD14592 00000EB6A86D 055843.1.FFFF 05F 061F39.1.0074 08EF49 ----- ------ 00002000 11111111
001B 00000CD14593 00000EB6A86E 055843.1.FFFF 060 061F39.1.0075 08FCA3 ----- ------ 00002000 11111111
001C 00000CD14594 00000EB6A86F 055843.1.FFFF 062 061F39.1.0076 0909BD ----- ------ 00002000 11111111
001D 00000CD145A1 00000EB6A872 055843.1.FFFF 078 061F39.1.0079 0931CB ----- ------ 00002000 11111111
001E 00000CD147D5 00000EB6A873 055840.1.FFFF 02C 061F39.1.007A 093F25 ----- ------ 00002000 11111111
001F 00000CD168AE 00000EB6A878 05581A.1.FFFF 04A 061F39.1.007F 0981E7 ----- ------ 00002000 11111111
0020 00000CD1A2DD 00000EB6A848 0557D7.1.FFFF 160 061F39.1.004F 070201 ----- ------ 00002010 11111111
0021 00000CD1A2FD 00000EB6A845 0557D7.1.FFFF 01D 061F39.1.004C 06D9F3 ----- ------ 00002010 11111111
0022 00000CD1A4A8 00000EB6A84A 0557D5.1.FFFF 040 061F39.1.0051 071CB5 ----- ------ 00002010 11111111
0023 00000CD1A4A9 00000EB6A84B 0557D5.1.FFFF 042 061F39.1.0052 072A0F ----- ------ 00002010 11111111
0024 00000DCF1842 00000EB6A84C 05F64B.1.FFFF 0C2 061F39.1.0053 073769 ----- ------ 00002610 11111111
0025 00000DCF1843 00000EB6A84D 05F64B.1.FFFF 0C4 061F39.1.0054 0744C3 ----- ------ 00002610 11111111
0026 00000DCF1844 00000EB6A84E 05F64B.1.FFFF 0C6 061F39.1.0055 07521D ----- ------ 00002610 11111111
0027 00000DCF1845 00000EB6A84F 05F64B.1.FFFF 0C8 061F39.1.0056 075F37 ----- ------ 00002610 11111111
0028 00000DCF18DE 00000EB6A850 05F64A.1.FFFF 099 061F39.1.0057 076C91 ----- ------ 00002610 11111111
0029 00000DCF18DF 00000EB6A851 05F64A.1.FFFF 09B 061F39.1.0058 0779EB ----- ------ 00002610 11111111
002A 00000DCF18E0 00000EB6A852 05F64A.1.FFFF 09C 061F39.1.0059 078745 ----- ------ 00002610 11111111
002B 00000DCF18E1 00000EB6A853 05F64A.1.FFFF 09E 061F39.1.005A 07949F ----- ------ 00002610 11111111
002C 00000DCF18E2 00000EB6A854 05F64A.1.FFFF 0A0 061F39.1.005B 07A1F9 ----- ------ 00002610 11111111
002D 00000EBCB411 00000EB6A684 0612D3.1.FFFF 104 061F37.1.0015 025989 ----- ------ 00042000 11111111
002E 00000EBCB413 00000EB6A688 0612D3.1.FFFF 106 061F37.1.0019 028EB1 ----- ------ 00042000 11111111
002F 00000EBCB414 00000EB6A689 0612D3.1.FFFF 107 061F37.1.001A 029C0B ----- ------ 00042000 11111111
0030 00000EBCB41F 00000EB6A68A 0612D3.1.FFFF 110 061F37.1.001B 02A965 ----- ------ 00042000 11111111
0031 00000EBCB420 00000EB6A68B 0612D3.1.FFFF 111 061F37.1.001C 02B6BF ----- ------ 00042000 11111111
0032 00000EBCB421 00000EB6A68C 0612D3.1.FFFF 112 061F37.1.001D 02C419 ----- ------ 00042000 11111111
0033 00000EBCB42E 00000EB6A68D 0612D3.1.FFFF 11E 061F37.1.001E 02D173 ----- ------ 00042000 11111111
0034 00000EBCB42F 00000EB6A836 0612D3.1.FFFF 11F 061F39.1.003D 061227 ----- ------ 00002600 11111111
0035 00000EBCB430 00000EB6A837 0612D3.1.FFFF 11F 061F39.1.003E 061F81 ----- ------ 00002610 11111111
0036 00000EBCB431 00000EB6A838 0612D3.1.FFFF 120 061F39.1.003F 062CDB ----- ------ 00002600 11111111
0037 00000EBCB432 00000EB6A839 0612D3.1.FFFF 121 061F39.1.0040 063A3B ----- ------ 00002610 11111111
0038 00000EBCB43B 00000EB6A68E 0612D3.1.FFFF 129 061F37.1.001F 02DECD ----- ------ 00042000 11111111
0039 00000EBCB43C 00000EB6A68F 0612D3.1.FFFF 12A 061F37.1.0020 02EC2D ----- ------ 00042000 11111111
003A 00000EBCB456 00000EB6A690 0612D3.1.FFFF 141 061F37.1.0021 02F947 ----- ------ 00042000 11111111
003B 00000EBCB4E9 00000EB6A691 0612D3.1.FFFF 04D 061F37.1.0022 0306A1 ----- ------ 00042000 11111111
003C 00000EBCB4F6 00000EB6A692 0612D3.1.FFFF 058 061F37.1.0023 0313FB ----- ------ 00042000 11111111
003D 00000EBCB4F7 00000EB6A693 0612D3.1.FFFF 059 061F37.1.0024 032155 ----- ------ 00042000 11111111
003E 00000EBCB504 00000EB6A694 0612D3.1.FFFF 065 061F37.1.0025 032EAF ----- ------ 00042000 11111111
003F 00000EBCB505 00000EB6A695 0612D3.1.FFFF 066 061F37.1.0026 033C09 ----- ------ 00042000 11111111
0040 00000EBCB511 00000EB6A696 0612D3.1.FFFF 070 061F37.1.0027 034963 ----- ------ 00042000 11111111
0041 00000EBCB512 00000EB6A697 0612D3.1.FFFF 071 061F37.1.0028 0356BD ----- ------ 00042000 11111111
0042 00000EBCB513 00000EB6A698 0612D3.1.FFFF 072 061F37.1.0029 036417 ----- ------ 00042000 11111111
0043 00000EBCB514 00000EB6A699 0612D3.1.FFFF 073 061F37.1.002A 037171 ----- ------ 00042000 11111111
0044 00000EBCB51F 00000EB6A69A 0612D3.1.FFFF 07C 061F37.1.002B 037E8B ----- ------ 00042000 11111111
0045 00000EBCB520 00000EB6A69B 0612D3.1.FFFF 07D 061F37.1.002C 038BE5 ----- ------ 00042000 11111111
0046 00000EBCB521 00000EB6A69C 0612D3.1.FFFF 07E 061F37.1.002D 03993F ----- ------ 00042000 11111111
0047 00000EBCB548 00000EB6A69D 0612D4.1.FFFF 0BF 061F37.1.002E 03A699 ----- ------ 00042000 11111111
0048 00000EBCB55A 00000EB6A69E 0612D4.1.FFFF 0CF 061F37.1.002F 03B3F3 ----- ------ 00042000 11111111
0049 00000EBCB55B 00000EB6A69F 0612D4.1.FFFF 0D0 061F37.1.0030 03C14D ----- ------ 00042000 11111111
004A 00000EBCB55C 00000EB6A6A0 0612D4.1.FFFF 0D1 061F37.1.0031 03CEA7 ----- ------ 00042000 11111111
004B 00000EBCB55D 00000EB6A6A1 0612D4.1.FFFF 0D2 061F37.1.0032 03DC01 ----- ------ 00042000 11111111
004C 00000EBCB55E 00000EB6A6A2 0612D4.1.FFFF 0D2 061F37.1.0033 03E95B ----- ------ 00042000 11111111
004D 00000EBCB567 00000EB6A6A3 0612D4.1.FFFF 0DA 061F37.1.0034 03F6B5 ----- ------ 00042000 11111111
004E 00000EBCB568 00000EB6A6A4 0612D4.1.FFFF 0DB 061F37.1.0035 04040F ----- ------ 00042000 11111111
004F 00000EBCB569 00000EB6A6A5 0612D4.1.FFFF 0DC 061F37.1.0036 041129 ----- ------ 00042000 11111111
0050 00000EBCB56A 00000EB6A6A6 0612D4.1.FFFF 0DD 061F37.1.0037 041E83 ----- ------ 00042000 11111111
0051 00000EBCB56B 00000EB6A6A7 0612D4.1.FFFF 0DE 061F37.1.0038 042BDD ----- ------ 00042000 11111111
0052 00000EBCB576 00000EB6A6A8 0612D4.1.FFFF 0E8 061F37.1.0039 043937 ----- ------ 00042000 11111111
0053 00000EBCB577 00000EB6A6A9 0612D4.1.FFFF 0E9 061F37.1.003A 044691 ----- ------ 00042000 11111111
0054 00000EBCB578 00000EB6A6AA 0612D4.1.FFFF 0E9 061F37.1.003B 0453EB ----- ------ 00042000 11111111
0055 00000EBCB583 00000EB6A6AB 0612D4.1.FFFF 0F3 061F37.1.003C 046145 ----- ------ 00042000 11111111
0056 00000EBCB584 00000EB6A6AC 0612D4.1.FFFF 0F4 061F37.1.003D 046E9F ----- ------ 00042000 11111111
0057 00000EBCB585 00000EB6A6AD 0612D4.1.FFFF 0F5 061F37.1.003E 047BF9 ----- ------ 00042000 11111111
0058 00000EBCB586 00000EB6A6AE 0612D4.1.FFFF 0F6 061F37.1.003F 048953 ----- ------ 00042000 11111111
0059 00000EBCB590 00000EB6A6AF 0612D4.1.FFFF 0FF 061F37.1.0040 0496B3 ----- ------ 00042000 11111111
005A 00000EBCB591 00000EB6A6B0 0612D4.1.FFFF 100 061F37.1.0041 04A3CD ----- ------ 00042000 11111111
005B 00000EBCB592 00000EB6A6B1 0612D4.1.FFFF 100 061F37.1.0042 04B127 ----- ------ 00042000 11111111
005C 00000EBCB593 00000EB6A6B2 0612D4.1.FFFF 101 061F37.1.0043 04BE81 ----- ------ 00042000 11111111
005D 00000EBCB59E 00000EB6A6B3 0612D4.1.FFFF 10B 061F37.1.0044 04CBDB ----- ------ 00042000 11111111
005E 00000EBCB59F 00000EB6A6B4 0612D4.1.FFFF 10C 061F37.1.0045 04D935 ----- ------ 00042000 11111111
005F 00000EBCB5A0 00000EB6A6B5 0612D4.1.FFFF 10D 061F37.1.0046 04E68F ----- ------ 00042000 11111111
0060 00000EBCB5A1 00000EB6A6B6 0612D4.1.FFFF 10E 061F37.1.0047 04F3E9 ----- ------ 00042000 11111111
0061 00000EBCB5AC 00000EB6A6B7 0612D4.1.FFFF 117 061F37.1.0048 050143 ----- ------ 00042000 11111111
0062 00000EBCB5AD 00000EB6A6B8 0612D4.1.FFFF 118 061F37.1.0049 050E9D ----- ------ 00042000 11111111
0063 00000EBCB5AE 00000EB6A6B9 0612D4.1.FFFF 119 061F37.1.004A 051BF7 ----- ------ 00042000 11111111
0064 00000EBCB5AF 00000EB6A6BA 0612D4.1.FFFF 11A 061F37.1.004B 052911 ----- ------ 00042000 11111111
0065 00000EBCB5B7 00000EB6A6BB 0612D4.1.FFFF 123 061F37.1.004C 05366B ----- ------ 00042000 11111111
0066 00000EBCB5B8 00000EB6A6BC 0612D4.1.FFFF 124 061F37.1.004D 0543C5 ----- ------ 00042000 11111111
0067 00000EBCB5B9 00000EB6A6BD 0612D4.1.FFFF 125 061F37.1.004E 05511F ----- ------ 00042000 11111111
0068 00000EBCB5BA 00000EB6A6BE 0612D4.1.FFFF 126 061F37.1.004F 055E79 ----- ------ 00042000 11111111
0069 00000EBCB5C5 00000EB6A6BF 0612D4.1.FFFF 12F 061F37.1.0050 056BD3 ----- ------ 00042000 11111111
006A 00000EBCB5C6 00000EB6A6C0 0612D4.1.FFFF 130 061F37.1.0051 05792D ----- ------ 00042000 11111111
006B 00000EBCB5C7 00000EB6A6C1 0612D4.1.FFFF 131 061F37.1.0052 058687 ----- ------ 00042000 11111111
006C 00000EBCB5D3 00000EB6A6C2 0612D4.1.FFFF 13C 061F37.1.0053 0593E1 ----- ------ 00042000 11111111
006D 00000EBCB5D4 00000EB6A6C3 0612D4.1.FFFF 13D 061F37.1.0054 05A13B ----- ------ 00042000 11111111
006E 00000EBCB5E0 00000EB6A6C4 0612D4.1.FFFF 147 061F37.1.0055 05AE95 ----- ------ 00042000 11111111
006F 00000EBCB5E1 00000EB6A6C5 0612D4.1.FFFF 148 061F37.1.0056 05BBAF ----- ------ 00042000 11111111
0070 00000EBCB5EE 00000EB6A6C6 0612D4.1.FFFF 154 061F37.1.0057 05C909 ----- ------ 00042000 11111111
0071 00000EBCB632 00000EB6A6C7 0612D4.1.FFFF 018 061F37.1.0058 05D663 ----- ------ 00042000 11111111
0072 00000EBCB63E 00000EB6A6C8 0612D4.1.FFFF 022 061F37.1.0059 05E3BD ----- ------ 00042000 11111111
0073 00000EBCB63F 00000EB6A6C9 0612D4.1.FFFF 023 061F37.1.005A 05F117 ----- ------ 00042000 11111111
0074 00000EBCB64C 00000EB6A6CA 0612D4.1.FFFF 02F 061F37.1.005B 05FE71 ----- ------ 00042000 11111111
0075 00000EBCB64D 00000EB6A6CB 0612D4.1.FFFF 030 061F37.1.005C 060BCB ----- ------ 00042000 11111111
0076 00000EBCB64E 00000EB6A82F 0612D4.1.FFFF 030 061F39.1.0036 05B4B1 ----- ------ 00002600 11111111
0077 00000EBCB64F 00000EB6A830 0612D4.1.FFFF 031 061F39.1.0037 05C20B ----- ------ 00002610 11111111
0078 00000EBCB650 00000EB6A831 0612D4.1.FFFF 032 061F39.1.0038 05CF65 ----- ------ 00002600 11111111
0079 00000EBCB651 00000EB6A832 0612D4.1.FFFF 033 061F39.1.0039 05DCBF ----- ------ 00002610 11111111
007A 00000EBCB652 00000EB6A833 0612D4.1.FFFF 034 061F39.1.003A 05EA19 ----- ------ 00002600 11111111
007B 00000EBCB653 00000EB6A834 0612D4.1.FFFF 035 061F39.1.003B 05F773 ----- ------ 00002610 11111111
007C 00000EBCB65A 00000EB6A6CC 0612D4.1.FFFF 03B 061F37.1.005D 061925 ----- ------ 00042000 11111111
007D 00000EBCB667 00000EB6A6CD 0612D4.1.FFFF 046 061F37.1.005E 06267F ----- ------ 00042000 11111111
007E 00000EBCB676 00000EB6A6CE 0612D4.1.FFFF 054 061F37.1.005F 0633D9 ----- ------ 00042000 11111111
007F 00000EBCB682 00000EB6A6CF 0612D4.1.FFFF 05E 061F37.1.0060 064139 ----- ------ 00042000 11111111
0080 00000EBCB68F 00000EB6A6D0 0612D4.1.FFFF 06C 061F37.1.0061 064E53 ----- ------ 00042000 11111111
0081 00000EBCB690 00000EB6A6D1 0612D4.1.FFFF 06D 061F37.1.0062 065BAD ----- ------ 00042000 11111111
0082 00000EBCB691 00000EB6A6D2 0612D4.1.FFFF 06D 061F37.1.0063 066907 ----- ------ 00042000 11111111
0083 00000EBCB69C 00000EB6A6D3 0612D4.1.FFFF 077 061F37.1.0064 067661 ----- ------ 00042000 11111111
0084 00000EBCB69D 00000EB6A6D4 0612D4.1.FFFF 078 061F37.1.0065 0683BB ----- ------ 00042000 11111111
0085 00000EBCB69E 00000EB6A6D5 0612D4.1.FFFF 079 061F37.1.0066 069115 ----- ------ 00042000 11111111
0086 00000EBCB6AE 00000EB6A6D6 0612D4.1.FFFF 087 061F37.1.0067 069E6F ----- ------ 00042000 11111111
0087 00000EBCB6AF 00000EB6A6D7 0612D4.1.FFFF 088 061F37.1.0068 06ABC9 ----- ------ 00042000 11111111
0088 00000EBCB6B0 00000EB6A6D8 0612D4.1.FFFF 089 061F37.1.0069 06B923 ----- ------ 00042000 11111111
0089 00000EBCB6B1 00000EB6A6D9 0612D4.1.FFFF 08A 061F37.1.006A 06C67D ----- ------ 00042000 11111111
008A 00000EBCB6C7 00000EB6A6DA 0612D4.1.FFFF 09D 061F37.1.006B 06D397 ----- ------ 00042000 11111111
008B 00000EBCB6D2 00000EB6A835 0612D4.1.FFFF 0A7 061F39.1.003C 0604CD ----- ------ 00002300 11111111
008C 00000EBCB6D3 00000EB6A6DC 0612D4.1.FFFF 0A8 061F37.1.006D 06EE4B ----- ------ 00042000 11111111
008D 00000EBCB6D4 00000EB6A6DD 0612D4.1.FFFF 0A9 061F37.1.006E 06FBA5 ----- ------ 00042000 11111111
008E 00000EBCB6D5 00000EB6A6DE 0612D4.1.FFFF 0AA 061F37.1.006F 0708FF ----- ------ 00042000 11111111
008F 00000EBCB700 00000EB6A6DF 0612D5.1.FFFF 0EE 061F37.1.0070 071659 ----- ------ 00042000 11111111
0090 00000EBCB701 00000EB6A6E0 0612D5.1.FFFF 0EF 061F37.1.0071 0723B3 ----- ------ 00042000 11111111
0091 00000EBCB702 00000EB6A6E1 0612D5.1.FFFF 0F0 061F37.1.0072 07310D ----- ------ 00042000 11111111
0092 00000EBCB70E 00000EB6A6E2 0612D5.1.FFFF 0FA 061F37.1.0073 073E67 ----- ------ 00042000 11111111
0093 00000EBCB70F 00000EB6A6E3 0612D5.1.FFFF 0FB 061F37.1.0074 074BC1 ----- ------ 00042000 11111111
0094 00000EBCB71B 00000EB6A6E4 0612D5.1.FFFF 106 061F37.1.0075 07591B ----- ------ 00042000 11111111
0095 00000EBCB71C 00000EB6A6E5 0612D5.1.FFFF 107 061F37.1.0076 076635 ----- ------ 00042000 11111111
0096 00000EBCB71D 00000EB6A6E6 0612D5.1.FFFF 107 061F37.1.0077 07738F ----- ------ 00042000 11111111
0097 00000EBCB71E 00000EB6A6E7 0612D5.1.FFFF 108 061F37.1.0078 0780E9 ----- ------ 00042000 11111111
0098 00000EBCB729 00000EB6A6E8 0612D5.1.FFFF 112 061F37.1.0079 078E43 ----- ------ 00042000 11111111
0099 00000EBCB72A 00000EB6A6E9 0612D5.1.FFFF 113 061F37.1.007A 079B9D ----- ------ 00042000 11111111
009A 00000EBCB72B 00000EB6A6EA 0612D5.1.FFFF 114 061F37.1.007B 07A8F7 ----- ------ 00042000 11111111
009B 00000EBCB736 00000EB6A6EB 0612D5.1.FFFF 11E 061F37.1.007C 07B651 ----- ------ 00042000 11111111
009C 00000EBCB737 00000EB6A6EC 0612D5.1.FFFF 11E 061F37.1.007D 07C3AB ----- ------ 00042000 11111111
009D 00000EBCB738 00000EB6A6ED 0612D5.1.FFFF 11F 061F37.1.007E 07D105 ----- ------ 00042000 11111111
009E 00000EBCB739 00000EB6A6EE 0612D5.1.FFFF 120 061F37.1.007F 07DE5F ----- ------ 00042000 11111111
009F 00000EBCB743 00000EB6A6EF 0612D5.1.FFFF 129 061F37.1.0080 07EBBF ----- ------ 00042000 11111111
00A0 00000EBCB744 00000EB6A6F0 0612D5.1.FFFF 12A 061F37.1.0081 07F8D9 ----- ------ 00042000 11111111
00A1 00000EBCB745 00000EB6A6F1 0612D5.1.FFFF 12B 061F37.1.0082 080633 ----- ------ 00042000 11111111
00A2 00000EBCB746 00000EB6A6F2 0612D5.1.FFFF 12C 061F37.1.0083 08138D ----- ------ 00042000 11111111
00A3 00000EBCB751 00000EB6A6F3 0612D5.1.FFFF 135 061F37.1.0084 0820E7 ----- ------ 00042000 11111111
00A4 00000EBCB752 00000EB6A6F4 0612D5.1.FFFF 136 061F37.1.0085 082E41 ----- ------ 00042000 11111111
00A5 00000EBCB753 00000EB6A6F5 0612D5.1.FFFF 137 061F37.1.0086 083B9B ----- ------ 00042000 11111111
00A6 00000EBCB754 00000EB6A6F6 0612D5.1.FFFF 138 061F37.1.0087 0848F5 ----- ------ 00042000 11111111
00A7 00000EBCB75C 00000EB6A6F7 0612D5.1.FFFF 141 061F37.1.0088 08564F ----- ------ 00042000 11111111
00A8 00000EBCB75D 00000EB6A6F8 0612D5.1.FFFF 142 061F37.1.0089 0863A9 ----- ------ 00042000 11111111
00A9 00000EBCB75E 00000EB6A6F9 0612D5.1.FFFF 143 061F37.1.008A 087103 ----- ------ 00042000 11111111
00AA 00000EBCB75F 00000EB6A6FA 0612D5.1.FFFF 144 061F37.1.008B 087E1D ----- ------ 00042000 11111111
00AB 00000EBCB76B 00000EB6A6FB 0612D5.1.FFFF 14E 061F37.1.008C 088B77 ----- ------ 00042000 11111111
00AC 00000EBCB76C 00000EB6A6FC 0612D5.1.FFFF 14F 061F37.1.008D 0898D1 ----- ------ 00042000 11111111
00AD 00000EBCB778 00000EB6A6FD 0612D5.1.FFFF 15A 061F37.1.008E 08A62B ----- ------ 00042000 11111111
00AE 00000EBCB779 00000EB6A6FE 0612D5.1.FFFF 15B 061F37.1.008F 08B385 ----- ------ 00042000 11111111
00AF 00000EBCB793 00000EB6A6FF 0612D5.1.FFFF 172 061F37.1.0090 08C0DF ----- ------ 00042000 11111111
00B0 00000EBCB7A0 00000EB6A700 0612D5.1.FFFF 005 061F37.1.0091 08CE39 ----- ------ 00042000 11111111
00B1 00000EBCB7A1 00000EB6A701 0612D5.1.FFFF 006 061F37.1.0092 08DB93 ----- ------ 00042000 11111111
00B2 00000EBCB7AD 00000EB6A702 0612D5.1.FFFF 010 061F37.1.0093 08E8ED ----- ------ 00042000 11111111
00B3 00000EBCB7AE 00000EB6A703 0612D5.1.FFFF 011 061F37.1.0094 08F647 ----- ------ 00042000 11111111
00B4 00000EBCB7BA 00000EB6A704 0612D5.1.FFFF 01C 061F37.1.0095 0903A1 ----- ------ 00042000 11111111
00B5 00000EBCB7BB 00000EB6A705 0612D5.1.FFFF 01D 061F37.1.0096 0910BB ----- ------ 00042000 11111111
00B6 00000EBCB7BC 00000EB6A706 0612D5.1.FFFF 01E 061F37.1.0097 091E15 ----- ------ 00042000 11111111
00B7 00000EBCB7BD 00000EB6A707 0612D5.1.FFFF 01F 061F37.1.0098 092B6F ----- ------ 00042000 11111111
00B8 00000EBCB7C9 00000EB6A708 0612D5.1.FFFF 029 061F37.1.0099 0938C9 ----- ------ 00042000 11111111
00B9 00000EBCB7CA 00000EB6A709 0612D5.1.FFFF 02A 061F37.1.009A 094623 ----- ------ 00042000 11111111
00BA 00000EBCB7D7 00000EB6A70A 0612D5.1.FFFF 036 061F37.1.009B 09537D ----- ------ 00042000 11111111
00BB 00000EBCB7E4 00000EB6A70B 0612D5.1.FFFF 041 061F37.1.009C 0960D7 ----- ------ 00042000 11111111
00BC 00000EBCB7E5 00000EB6A70C 0612D5.1.FFFF 042 061F37.1.009D 096E31 ----- ------ 00042000 11111111
00BD 00000EBCB7F1 00000EB6A70D 0612D5.1.FFFF 04D 061F37.1.009E 097B8B ----- ------ 00042000 11111111
00BE 00000EBCB7F2 00000EB6A70E 0612D5.1.FFFF 04E 061F37.1.009F 0988E5 ----- ------ 00042000 11111111
00BF 00000EBCB7FE 00000EB6A70F 0612D5.1.FFFF 058 061F37.1.00A0 099645 ----- ------ 00042000 11111111
00C0 00000EBCB7FF 00000EB6A710 0612D5.1.FFFF 059 061F37.1.00A1 09A35F ----- ------ 00042000 11111111
00C1 00000EBCB800 00000EB6A711 0612D5.1.FFFF 05A 061F37.1.00A2 09B0B9 ----- ------ 00042000 11111111
00C2 00000EBCB801 00000EB6A712 0612D5.1.FFFF 05B 061F37.1.00A3 09BE13 ----- ------ 00042000 11111111
00C3 00000EBCB802 00000EB6A713 0612D5.1.FFFF 05C 061F37.1.00A4 09CB6D ----- ------ 00042000 11111111
00C4 00000EBCB80C 00000EB6A714 0612D5.1.FFFF 064 061F37.1.00A5 09D8C7 ----- ------ 00042000 11111111
00C5 00000EBCB80D 00000EB6A715 0612D5.1.FFFF 065 061F37.1.00A6 09E621 ----- ------ 00042000 11111111
00C6 00000EBCB80E 00000EB6A716 0612D5.1.FFFF 066 061F37.1.00A7 09F37B ----- ------ 00042000 11111111
00C7 00000EBCB80F 00000EB6A717 0612D5.1.FFFF 067 061F37.1.00A8 0A00D5 ----- ------ 00042000 11111111
00C8 00000EBCB810 00000EB6A718 0612D5.1.FFFF 068 061F37.1.00A9 0A0E2F ----- ------ 00042000 11111111
00C9 00000EBCB81A 00000EB6A719 0612D5.1.FFFF 071 061F37.1.00AA 0A1B89 ----- ------ 00042000 11111111
00CA 00000EBCB81B 00000EB6A71A 0612D5.1.FFFF 072 061F37.1.00AB 0A28A3 ----- ------ 00042000 11111111
00CB 00000EBCB81C 00000EB6A71B 0612D5.1.FFFF 073 061F37.1.00AC 0A35FD ----- ------ 00042000 11111111
00CC 00000EBCB81D 00000EB6A71C 0612D5.1.FFFF 074 061F37.1.00AD 0A4357 ----- ------ 00042000 11111111
00CD 00000EBCB84E 00000EB6A71D 0612D5.1.FFFF 0A1 061F37.1.00AE 000BA1 ----- ------ 00042000 11111111
00CE 00000EBCB84F 00000EB6A71E 0612D5.1.FFFF 0A2 061F37.1.00AF 0018FB ----- ------ 00042000 11111111
00CF 00000EBCB850 00000EB6A71F 0612D5.1.FFFF 0A2 061F37.1.00B0 002655 ----- ------ 00042000 11111111
00D0 00000EBCB851 00000EB6A720 0612D5.1.FFFF 0A3 061F37.1.00B1 0033AF ----- ------ 00042000 11111111
00D1 00000EBCB85C 00000EB6A721 0612D5.1.FFFF 0AD 061F37.1.00B2 004109 ----- ------ 00042000 11111111
00D2 00000EBCB85D 00000EB6A722 0612D5.1.FFFF 0AE 061F37.1.00B3 004E63 ----- ------ 00042000 11111111
00D3 00000EBCB85E 00000EB6A723 0612D5.1.FFFF 0AF 061F37.1.00B4 005BBD ----- ------ 00042000 11111111
00D4 00000EBCB868 00000EB6A724 0612D5.1.FFFF 0B8 061F37.1.00B5 006917 ----- ------ 00042000 11111111
00D5 00000EBCB869 00000EB6A725 0612D5.1.FFFF 0B8 061F37.1.00B6 007631 ----- ------ 00042000 11111111
00D6 00000EBCB86A 00000EB6A726 0612D5.1.FFFF 0B9 061F37.1.00B7 00838B ----- ------ 00042000 11111111
00D7 00000EBCB86B 00000EB6A727 0612D5.1.FFFF 0BA 061F37.1.00B8 0090E5 ----- ------ 00042000 11111111
00D8 00000EBCB875 00000EB6A728 0612D5.1.FFFF 0C3 061F37.1.00B9 009E3F ----- ------ 00042000 11111111
00D9 00000EBCB876 00000EB6A729 0612D5.1.FFFF 0C4 061F37.1.00BA 00AB99 ----- ------ 00042000 11111111
00DA 00000EBCB877 00000EB6A72A 0612D5.1.FFFF 0C5 061F37.1.00BB 00B8F3 ----- ------ 00042000 11111111
00DB 00000EBCB878 00000EB6A72B 0612D5.1.FFFF 0C6 061F37.1.00BC 00C64D ----- ------ 00042000 11111111
00DC 00000EBCB879 00000EB6A72C 0612D5.1.FFFF 0C7 061F37.1.00BD 00D3A7 ----- ------ 00042000 11111111
00DD 00000EBCB8A4 00000EB6A72D 0612D6.1.FFFF 10B 061F37.1.00BE 00E101 ----- ------ 00042000 11111111
00DE 00000EBCB8A5 00000EB6A72E 0612D6.1.FFFF 10C 061F37.1.00BF 00EE5B ----- ------ 00042000 11111111
00DF 00000EBCB8A6 00000EB6A72F 0612D6.1.FFFF 10D 061F37.1.00C0 00FBBB ----- ------ 00042000 11111111
00E0 00000EBCB8A7 00000EB6A730 0612D6.1.FFFF 10E 061F37.1.00C1 0108D5 ----- ------ 00042000 11111111
00E1 00000EBCB8B1 00000EB6A731 0612D6.1.FFFF 116 061F37.1.00C2 01162F ----- ------ 00042000 11111111
00E2 00000EBCB8B2 00000EB6A732 0612D6.1.FFFF 117 061F37.1.00C3 012389 ----- ------ 00042000 11111111
00E3 00000EBCB8B3 00000EB6A733 0612D6.1.FFFF 118 061F37.1.00C4 0130E3 ----- ------ 00042000 11111111
00E4 00000EBCB8B4 00000EB6A734 0612D6.1.FFFF 119 061F38.1.0000 02136B ----- ------ 00000122 00000000
00E5 00000EBCB8BF 00000EB6A735 0612D6.1.FFFF 123 061F38.1.0001 022085 ----- ------ 00042000 11111111
00E6 00000EBCB8C0 00000EB6A736 0612D6.1.FFFF 124 061F38.1.0002 022DDF ----- ------ 00042000 11111111
00E7 00000EBCB8C1 00000EB6A737 0612D6.1.FFFF 125 061F38.1.0003 023B39 ----- ------ 00042000 11111111
00E8 00000EBCB8C2 00000EB6A738 0612D6.1.FFFF 125 061F38.1.0004 024893 ----- ------ 00042000 11111111
00E9 00000EBCB8C3 00000EB6A739 0612D6.1.FFFF 126 061F38.1.0005 0255ED ----- ------ 00042000 11111111
00EA 00000EBCB8CD 00000EB6A73A 0612D6.1.FFFF 12F 061F38.1.0006 026347 ----- ------ 00042000 11111111
00EB 00000EBCB8CE 00000EB6A73B 0612D6.1.FFFF 130 061F38.1.0007 0270A1 ----- ------ 00042000 11111111
00EC 00000EBCB8CF 00000EB6A73D 0612D6.1.FFFF 131 061F38.1.0009 028B55 ----- ------ 00042000 11111111
00ED 00000EBCB8DA 00000EB6A73E 0612D6.1.FFFF 13B 061F38.1.000A 0298AF ----- ------ 00042000 11111111
00EE 00000EBCB8DB 00000EB6A73F 0612D6.1.FFFF 13C 061F38.1.000B 02A5C9 ----- ------ 00042000 11111111
00EF 00000EBCB8DC 00000EB6A740 0612D6.1.FFFF 13C 061F38.1.000C 02B323 ----- ------ 00042000 11111111
00F0 00000EBCB8DD 00000EB6A741 0612D6.1.FFFF 13D 061F38.1.000D 02C07D ----- ------ 00042000 11111111
00F1 00000EBCB8E8 00000EB6A742 0612D6.1.FFFF 147 061F38.1.000E 02CDD7 ----- ------ 00042000 11111111
00F2 00000EBCB8E9 00000EB6A743 0612D6.1.FFFF 148 061F38.1.000F 02DB31 ----- ------ 00042000 11111111
00F3 00000EBCB8EA 00000EB6A744 0612D6.1.FFFF 149 061F38.1.0010 02E88B ----- ------ 00042000 11111111
00F4 00000EBCB8EB 00000EB6A745 0612D6.1.FFFF 14A 061F38.1.0011 02F5E5 ----- ------ 00042000 11111111
00F5 00000EBCB8F7 00000EB6A746 0612D6.1.FFFF 154 061F38.1.0012 03033F ----- ------ 00042000 11111111
00F6 00000EBCB8F8 00000EB6A747 0612D6.1.FFFF 155 061F38.1.0013 031099 ----- ------ 00042000 11111111
00F7 00000EBCB902 00000EB6A748 0612D6.1.FFFF 160 061F38.1.0014 031DF3 ----- ------ 00042000 11111111
00F8 00000EBCB903 00000EB6A749 0612D6.1.FFFF 161 061F38.1.0015 032B4D ----- ------ 00042000 11111111
00F9 00000EBCB910 00000EB6A74A 0612D6.1.FFFF 16C 061F38.1.0016 033867 ----- ------ 00042000 11111111
00FA 00000EBCB91D 00000EB6A74B 0612D6.1.FFFF 000 061F38.1.0017 0345C1 ----- ------ 00042000 11111111
00FB 00000EBCB92A 00000EB6A74C 0612D6.1.FFFF 00B 061F38.1.0018 03531B ----- ------ 00042000 11111111
00FC 00000EBCB92B 00000EB6A74D 0612D6.1.FFFF 00C 061F38.1.0019 036075 ----- ------ 00042000 11111111
00FD 00000EBCB945 00000EB6A74E 0612D6.1.FFFF 023 061F38.1.001A 036DCF ----- ------ 00042000 11111111
00FE 00000EBCB952 00000EB6A74F 0612D6.1.FFFF 02E 061F38.1.001B 037B29 ----- ------ 00042000 11111111
00FF 00000EBCB960 00000EB6A750 0612D6.1.FFFF 03B 061F38.1.001C 038883 ----- ------ 00042000 11111111
0100 00000EBCB961 00000EB6A751 0612D6.1.FFFF 03C 061F38.1.001D 0395DD ----- ------ 00042000 11111111
0101 00000EBCB96C 00000EB6A752 0612D6.1.FFFF 045 061F38.1.001E 03A337 ----- ------ 00042000 11111111
0102 00000EBCB96D 00000EB6A753 0612D6.1.FFFF 046 061F38.1.001F 03B091 ----- ------ 00042000 11111111
0103 00000EBCB96E 00000EB6A754 0612D6.1.FFFF 047 061F38.1.0020 03BDF1 ----- ------ 00042000 11111111
0104 00000EBCB96F 00000EB6A755 0612D6.1.FFFF 048 061F38.1.0021 03CB0B ----- ------ 00042000 11111111
0105 00000EBCB97B 00000EB6A756 0612D6.1.FFFF 053 061F38.1.0022 03D865 ----- ------ 00042000 11111111
0106 00000EBCB97C 00000EB6A757 0612D6.1.FFFF 054 061F38.1.0023 03E5BF ----- ------ 00042000 11111111
0107 00000EBCB988 00000EB6A758 0612D6.1.FFFF 05E 061F38.1.0024 03F319 ----- ------ 00042000 11111111
0108 00000EBCB989 00000EB6A759 0612D6.1.FFFF 05F 061F38.1.0025 040073 ----- ------ 00042000 11111111
0109 00000EBCB98A 00000EB6A75A 0612D6.1.FFFF 060 061F38.1.0026 040DCD ----- ------ 00042000 11111111
010A 00000EBCB98B 00000EB6A75B 0612D6.1.FFFF 061 061F38.1.0027 041B27 ----- ------ 00042000 11111111
010B 00000EBCB98C 00000EB6A75C 0612D6.1.FFFF 062 061F38.1.0028 042881 ----- ------ 00042000 11111111
010C 00000EBCB996 00000EB6A75D 0612D6.1.FFFF 06B 061F38.1.0029 0435DB ----- ------ 00042000 11111111
010D 00000EBCB997 00000EB6A75E 0612D6.1.FFFF 06C 061F38.1.002A 044335 ----- ------ 00042000 11111111
010E 00000EBCB998 00000EB6A75F 0612D6.1.FFFF 06C 061F38.1.002B 04504F ----- ------ 00042000 11111111
010F 00000EBCB999 00000EB6A760 0612D6.1.FFFF 06D 061F38.1.002C 045DA9 ----- ------ 00042000 11111111
0110 00000EBCB99A 00000EB6A761 0612D6.1.FFFF 06E 061F38.1.002D 046B03 ----- ------ 00042000 11111111
0111 00000EBCB9BD 00000EB6A762 0612D6.1.FFFF 08D 061F38.1.002E 04785D ----- ------ 00042000 11111111
0112 00000EBCB9BE 00000EB6A763 0612D6.1.FFFF 08E 061F38.1.002F 0485B7 ----- ------ 00042000 11111111
0113 00000EBCB9BF 00000EB6A764 0612D6.1.FFFF 08F 061F38.1.0030 049311 ----- ------ 00042000 11111111
0114 00000EBCB9C0 00000EB6A765 0612D6.1.FFFF 090 061F38.1.0031 04A06B ----- ------ 00042000 11111111
0115 00000EBCB9C1 00000EB6A766 0612D6.1.FFFF 091 061F38.1.0032 04ADC5 ----- ------ 00042000 11111111
0116 00000EBCB9CB 00000EB6A767 0612D6.1.FFFF 09B 061F38.1.0033 04BB1F ----- ------ 00042000 11111111
0117 00000EBCB9CC 00000EB6A768 0612D6.1.FFFF 09C 061F38.1.0034 04C879 ----- ------ 00042000 11111111
0118 00000EBCB9CD 00000EB6A769 0612D6.1.FFFF 09D 061F38.1.0035 04D5D3 ----- ------ 00042000 11111111
0119 00000EBCB9D6 00000EB6A76A 0612D6.1.FFFF 0A5 061F38.1.0036 04E2ED ----- ------ 00042000 11111111
011A 00000EBCB9D7 00000EB6A76B 0612D6.1.FFFF 0A6 061F38.1.0037 04F047 ----- ------ 00042000 11111111
011B 00000EBCB9D8 00000EB6A76C 0612D6.1.FFFF 0A7 061F38.1.0038 04FDA1 ----- ------ 00042000 11111111
011C 00000EBCB9D9 00000EB6A76D 0612D6.1.FFFF 0A8 061F38.1.0039 050AFB ----- ------ 00042000 11111111
011D 00000EBCB9DA 00000EB6A76E 0612D6.1.FFFF 0A9 061F38.1.003A 051855 ----- ------ 00042000 11111111
011E 00000EBCB9E4 00000EB6A76F 0612D6.1.FFFF 0B1 061F38.1.003B 0525AF ----- ------ 00042000 11111111
011F 00000EBCB9E5 00000EB6A770 0612D6.1.FFFF 0B2 061F38.1.003C 053309 ----- ------ 00042000 11111111
0120 00000EBCB9E6 00000EB6A771 0612D6.1.FFFF 0B3 061F38.1.003D 054063 ----- ------ 00042000 11111111
0121 00000EBCB9E7 00000EB6A772 0612D6.1.FFFF 0B4 061F38.1.003E 054DBD ----- ------ 00042000 11111111
0122 00000EBCB9F1 00000EB6A773 0612D6.1.FFFF 0BD 061F38.1.003F 055B17 ----- ------ 00042000 11111111
0123 00000EBCB9F2 00000EB6A774 0612D6.1.FFFF 0BE 061F38.1.0040 056877 ----- ------ 00042000 11111111
0124 00000EBCB9F3 00000EB6A775 0612D6.1.FFFF 0BF 061F38.1.0041 057591 ----- ------ 00042000 11111111
0125 00000EBCB9F4 00000EB6A776 0612D6.1.FFFF 0C0 061F38.1.0042 0582EB ----- ------ 00042000 11111111
0126 00000EBCB9F5 00000EB6A777 0612D6.1.FFFF 0C0 061F38.1.0043 059045 ----- ------ 00042000 11111111
0127 00000EBCB9F6 00000EB6A778 0612D6.1.FFFF 0C1 061F38.1.0044 059D9F ----- ------ 00042000 11111111
0128 00000EBCB9FF 00000EB6A779 0612D6.1.FFFF 0C9 061F38.1.0045 05AAF9 ----- ------ 00042000 11111111
0129 00000EBCBA00 00000EB6A77A 0612D6.1.FFFF 0CA 061F38.1.0046 05B853 ----- ------ 00042000 11111111
012A 00000EBCBA01 00000EB6A77B 0612D6.1.FFFF 0CB 061F38.1.0047 05C5AD ----- ------ 00042000 11111111
012B 00000EBCBA02 00000EB6A77C 0612D6.1.FFFF 0CC 061F38.1.0048 05D307 ----- ------ 00042000 11111111
012C 00000EBCBA03 00000EB6A77D 0612D6.1.FFFF 0CD 061F38.1.0049 05E061 ----- ------ 00042000 11111111
012D 00000EBCBA0D 00000EB6A77E 0612D6.1.FFFF 0D6 061F38.1.004A 05EDBB ----- ------ 00042000 11111111
012E 00000EBCBA0E 00000EB6A77F 0612D6.1.FFFF 0D6 061F38.1.004B 05FAD5 ----- ------ 00042000 11111111
012F 00000EBCBA0F 00000EB6A780 0612D6.1.FFFF 0D7 061F38.1.004C 06082F ----- ------ 00042000 11111111
0130 00000EBCBA10 00000EB6A781 0612D6.1.FFFF 0D8 061F38.1.004D 061589 ----- ------ 00042000 11111111
0131 00000EBCBA1A 00000EB6A782 0612D6.1.FFFF 0E1 061F38.1.004E 0622E3 ----- ------ 00042000 11111111
0132 00000EBCBA1B 00000EB6A783 0612D6.1.FFFF 0E2 061F38.1.004F 06303D ----- ------ 00042000 11111111
0133 00000EBCBA1C 00000EB6A784 0612D6.1.FFFF 0E3 061F38.1.0050 063D97 ----- ------ 00042000 11111111
0134 00000EBCBA1D 00000EB6A785 0612D6.1.FFFF 0E4 061F38.1.0051 064AF1 ----- ------ 00042000 11111111
0135 00000EBCBA1E 00000EB6A786 0612D6.1.FFFF 0E5 061F38.1.0052 06584B ----- ------ 00042000 11111111
0136 00000EBCBA49 00000EB6A787 0612D7.1.FFFF 129 061F38.1.0053 0665A5 ----- ------ 00042000 11111111
0137 00000EBCBA4A 00000EB6A788 0612D7.1.FFFF 12A 061F38.1.0054 0672FF ----- ------ 00042000 11111111
0138 00000EBCBA4B 00000EB6A789 0612D7.1.FFFF 12B 061F38.1.0055 068059 ----- ------ 00042000 11111111
0139 00000EBCBA56 00000EB6A78A 0612D7.1.FFFF 134 061F38.1.0056 068D73 ----- ------ 00042000 11111111
013A 00000EBCBA57 00000EB6A78B 0612D7.1.FFFF 135 061F38.1.0057 069ACD ----- ------ 00042000 11111111
013B 00000EBCBA58 00000EB6A78C 0612D7.1.FFFF 136 061F38.1.0058 06A827 ----- ------ 00042000 11111111
013C 00000EBCBA59 00000EB6A78D 0612D7.1.FFFF 137 061F38.1.0059 06B581 ----- ------ 00042000 11111111
013D 00000EBCBA63 00000EB6A78E 0612D7.1.FFFF 140 061F38.1.005A 06C2DB ----- ------ 00042000 11111111
013E 00000EBCBA64 00000EB6A78F 0612D7.1.FFFF 141 061F38.1.005B 06D035 ----- ------ 00042000 11111111
013F 00000EBCBA65 00000EB6A790 0612D7.1.FFFF 142 061F38.1.005C 06DD8F ----- ------ 00042000 11111111
0140 00000EBCBA66 00000EB6A791 0612D7.1.FFFF 143 061F38.1.005D 06EAE9 ----- ------ 00042000 11111111
0141 00000EBCBA72 00000EB6A792 0612D7.1.FFFF 14D 061F38.1.005E 06F843 ----- ------ 00042000 11111111
0142 00000EBCBA73 00000EB6A793 0612D7.1.FFFF 14E 061F38.1.005F 07059D ----- ------ 00042000 11111111
0143 00000EBCBA80 00000EB6A794 0612D7.1.FFFF 15A 061F38.1.0060 0712FD ----- ------ 00042000 11111111
0144 00000EBCBACE 00000EB6A795 0612D7.1.FFFF 028 061F38.1.0061 072017 ----- ------ 00042000 11111111
0145 00000EBCBACF 00000EB6A796 0612D7.1.FFFF 029 061F38.1.0062 072D71 ----- ------ 00042000 11111111
0146 00000EBCBADC 00000EB6A797 0612D7.1.FFFF 035 061F38.1.0063 073ACB ----- ------ 00042000 11111111
0147 00000EBCBAE9 00000EB6A798 0612D7.1.FFFF 040 061F38.1.0064 074825 ----- ------ 00042000 11111111
0148 00000EBCBAEA 00000EB6A799 0612D7.1.FFFF 041 061F38.1.0065 07557F ----- ------ 00042000 11111111
0149 00000EBCBAF6 00000EB6A79A 0612D7.1.FFFF 04C 061F38.1.0066 0762D9 ----- ------ 00042000 11111111
014A 00000EBCBAF7 00000EB6A79B 0612D7.1.FFFF 04C 061F38.1.0067 077033 ----- ------ 00042000 11111111
014B 00000EBCBAF8 00000EB6A79C 0612D7.1.FFFF 04D 061F38.1.0068 077D8D ----- ------ 00042000 11111111
014C 00000EBCBB04 00000EB6A79D 0612D7.1.FFFF 058 061F38.1.0069 078AE7 ----- ------ 00042000 11111111
014D 00000EBCBB11 00000EB6A79E 0612D7.1.FFFF 063 061F38.1.006A 079841 ----- ------ 00042000 11111111
014E 00000EBCBB12 00000EB6A79F 0612D7.1.FFFF 064 061F38.1.006B 07A55B ----- ------ 00042000 11111111
014F 00000EBCBB13 00000EB6A7A0 0612D7.1.FFFF 065 061F38.1.006C 07B2B5 ----- ------ 00042000 11111111
0150 00000EBCBB14 00000EB6A7A1 0612D7.1.FFFF 066 061F38.1.006D 07C00F ----- ------ 00042000 11111111
0151 00000EBCBB22 00000EB6A7A2 0612D7.1.FFFF 073 061F38.1.006E 07CD69 ----- ------ 00042000 11111111
0152 00000EBCBB23 00000EB6A7A3 0612D7.1.FFFF 073 061F38.1.006F 07DAC3 ----- ------ 00042000 11111111
0153 00000EBCBB24 00000EB6A7A4 0612D7.1.FFFF 074 061F38.1.0070 07E81D ----- ------ 00042000 11111111
0154 00000EBCBB25 00000EB6A7A5 0612D7.1.FFFF 075 061F38.1.0071 07F577 ----- ------ 00042000 11111111
0155 00000EBCBB26 00000EB6A7A6 0612D7.1.FFFF 076 061F38.1.0072 0802D1 ----- ------ 00042000 11111111
0156 00000EBCBB33 00000EB6A7A7 0612D7.1.FFFF 082 061F38.1.0073 08102B ----- ------ 00042000 11111111
0157 00000EBCBB34 00000EB6A7A8 0612D7.1.FFFF 082 061F38.1.0074 081D85 ----- ------ 00042000 11111111
0158 00000EBCBB6F 00000EB6A7A9 0612D7.1.FFFF 0B8 061F38.1.0075 082ADF ----- ------ 00042000 11111111
0159 00000EBCBB70 00000EB6A7AA 0612D7.1.FFFF 0B9 061F38.1.0076 0837F9 ----- ------ 00042000 11111111
015A 00000EBCBB71 00000EB6A7AB 0612D7.1.FFFF 0BA 061F38.1.0077 084553 ----- ------ 00042000 11111111
015B 00000EBCBB72 00000EB6A7AC 0612D7.1.FFFF 0BB 061F38.1.0078 0852AD ----- ------ 00042000 11111111
015C 00000EBCBB7C 00000EB6A7AD 0612D7.1.FFFF 0C4 061F38.1.0079 086007 ----- ------ 00042000 11111111
015D 00000EBCBB7D 00000EB6A7AE 0612D7.1.FFFF 0C5 061F38.1.007A 086D61 ----- ------ 00042000 11111111
015E 00000EBCBB7E 00000EB6A7AF 0612D7.1.FFFF 0C6 061F38.1.007B 087ABB ----- ------ 00042000 11111111
015F 00000EBCBB7F 00000EB6A7B0 0612D7.1.FFFF 0C7 061F38.1.007C 088815 ----- ------ 00042000 11111111
0160 00000EBCBB80 00000EB6A7B1 0612D7.1.FFFF 0C7 061F38.1.007D 08956F ----- ------ 00042000 11111111
0161 00000EBCBB8B 00000EB6A7B2 0612D7.1.FFFF 0D1 061F38.1.007E 08A2C9 ----- ------ 00042000 11111111
0162 00000EBCBB8C 00000EB6A7B3 0612D7.1.FFFF 0D2 061F38.1.007F 08B023 ----- ------ 00042000 11111111
0163 00000EBCBB8D 00000EB6A7B4 0612D7.1.FFFF 0D3 061F38.1.0080 08BD83 ----- ------ 00042000 11111111
0164 00000EBCBB98 00000EB6A7B5 0612D7.1.FFFF 0DD 061F38.1.0081 08CA9D ----- ------ 00042000 11111111
0165 00000EBCBB99 00000EB6A7B6 0612D7.1.FFFF 0DE 061F38.1.0082 08D7F7 ----- ------ 00042000 11111111
0166 00000EBCBB9B 00000EB6A7B7 0612D7.1.FFFF 0DF 061F38.1.0083 08E551 ----- ------ 00042000 11111111
0167 00000EBCBBA6 00000EB6A7B8 0612D7.1.FFFF 0E9 061F38.1.0084 08F2AB ----- ------ 00042000 11111111
0168 00000EBCBBB3 00000EB6A7B9 0612D7.1.FFFF 0F4 061F38.1.0085 090005 ----- ------ 00042000 11111111
0169 00000EBCBBC0 00000EB6A7BA 0612D7.1.FFFF 100 061F38.1.0086 090D5F ----- ------ 00042000 11111111
016A 00000EBCBBC1 00000EB6A7BB 0612D7.1.FFFF 101 061F38.1.0087 091AB9 ----- ------ 00042000 11111111
016B 00000EBCBBC2 00000EB6A7BC 0612D7.1.FFFF 102 061F38.1.0088 092813 ----- ------ 00042000 11111111
016C 00000EBCBBC3 00000EB6A7BD 0612D7.1.FFFF 103 061F38.1.0089 09356D ----- ------ 00042000 11111111
016D 00000EBCBBC6 00000EB6A7BE 0612D8.1.FFFF 124 061F38.1.008A 0942C7 ----- ------ 00042000 11111111
016E 00000EBCBBC7 00000EB6A7BF FFFFFFFF.FF.FFFF 124 061F38.1.008B 094FE1 ----- ------ 00042000 11111111
016F 00000EBCBBD2 00000EB6A7C0 FFFFFFFF.FF.FFFF 12E 061F38.1.008C 095D3B ----- ------ 00042000 11111111
0170 00000EBCBBD3 00000EB6A7C1 FFFFFFFF.FF.FFFF 12F 061F38.1.008D 096A95 ----- ------ 00042000 11111111
0171 00000EBCBBD4 00000EB6A7C2 FFFFFFFF.FF.FFFF 130 061F38.1.008E 0977EF ----- ------ 00042000 11111111
0172 00000EBCBBD5 00000EB6A7C3 FFFFFFFF.FF.FFFF 131 061F38.1.008F 098549 ----- ------ 00042000 11111111
0173 00000EBCBBE0 00000EB6A7C4 FFFFFFFF.FF.FFFF 13A 061F38.1.0090 0992A3 ----- ------ 00042000 11111111
0174 00000EBCBBE1 00000EB6A7C5 FFFFFFFF.FF.FFFF 13B 061F38.1.0091 099FFD ----- ------ 00042000 11111111
0175 00000EBCBBE2 00000EB6A7C6 FFFFFFFF.FF.FFFF 13C 061F38.1.0092 09AD57 ----- ------ 00042000 11111111
0176 00000EBCBBE3 00000EB6A7C7 FFFFFFFF.FF.FFFF 13D 061F38.1.0093 09BAB1 ----- ------ 00042000 11111111
0177 00000EBCBBEF 00000EB6A7C8 FFFFFFFF.FF.FFFF 148 061F38.1.0094 09C80B ----- ------ 00042000 11111111
0178 00000EBCBBF0 00000EB6A7C9 FFFFFFFF.FF.FFFF 149 061F38.1.0095 09D565 ----- ------ 00042000 11111111
0179 00000EBCBBFB 00000EB6A7CA FFFFFFFF.FF.FFFF 152 061F38.1.0096 09E27F ----- ------ 00042000 11111111
017A 00000EBCBBFC 00000EB6A7CB FFFFFFFF.FF.FFFF 153 061F38.1.0097 09EFD9 ----- ------ 00042000 11111111
017B 00000EBCBBFD 00000EB6A7CC FFFFFFFF.FF.FFFF 154 061F38.1.0098 09FD33 ----- ------ 00042000 11111111
017C 00000EBCBC24 00000EB6A7CD FFFFFFFF.FF.FFFF 177 061F38.1.0099 0A0A8D ----- ------ 00042000 11111111
017D 00000EBCBC4A 00000EB6A7CE FFFFFFFF.FF.FFFF 022 061F38.1.009A 0A17E7 ----- ------ 00042000 11111111
017E 00000EBCBC73 00000EB6A7CF FFFFFFFF.FF.FFFF 046 061F38.1.009B 0A2541 ----- ------ 00042000 11111111
017F 00000EBCBC74 00000EB6A7D0 FFFFFFFF.FF.FFFF 047 061F38.1.009C 0A329B ----- ------ 00042000 11111111
0180 00000EBCBC81 00000EB6A7D1 FFFFFFFF.FF.FFFF 053 061F38.1.009D 0A3FF5 ----- ------ 00042000 11111111
0181 00000EBCBC8E 00000EB6A7D2 FFFFFFFF.FF.FFFF 05E 061F38.1.009E 00083F ----- ------ 00042000 11111111
0182 00000EBCBC8F 00000EB6A7D3 FFFFFFFF.FF.FFFF 05F 061F38.1.009F 001599 ----- ------ 00042000 11111111
0183 00000EBCBC9C 00000EB6A7D4 FFFFFFFF.FF.FFFF 06A 061F38.1.00A0 0022F9 ----- ------ 00042000 11111111
0184 00000EBCBC9E 00000EB6A7D5 FFFFFFFF.FF.FFFF 06C 061F38.1.00A1 003013 ----- ------ 00042000 11111111
0185 00000EBCBCAC 00000EB6A7D6 FFFFFFFF.FF.FFFF 079 061F38.1.00A2 003D6D ----- ------ 00042000 11111111
0186 00000EBCBCAD 00000EB6A7D7 FFFFFFFF.FF.FFFF 07A 061F38.1.00A3 004AC7 ----- ------ 00042000 11111111
0187 00000EBCBCAE 00000EB6A7D8 FFFFFFFF.FF.FFFF 07A 061F38.1.00A4 005821 ----- ------ 00042000 11111111
0188 00000EBCBCBB 00000EB6A7D9 FFFFFFFF.FF.FFFF 086 061F38.1.00A5 00657B ----- ------ 00042000 11111111
0189 00000EBCBCBC 00000EB6A7DA FFFFFFFF.FF.FFFF 087 061F38.1.00A6 0072D5 ----- ------ 00042000 11111111
018A 00000EBCBCBD 00000EB6A7DB FFFFFFFF.FF.FFFF 088 061F38.1.00A7 00802F ----- ------ 00042000 11111111
018B 00000EBCBCBE 00000EB6A7DC FFFFFFFF.FF.FFFF 089 061F38.1.00A8 008D89 ----- ------ 00042000 11111111
018C 00000EBCBCCA 00000EB6A7DD FFFFFFFF.FF.FFFF 093 061F38.1.00A9 009AE3 ----- ------ 00042000 11111111
018D 00000EBCBCCB 00000EB6A7DE FFFFFFFF.FF.FFFF 094 061F38.1.00AA 00A83D ----- ------ 00042000 11111111
018E 00000EBCBCCC 00000EB6A7DF FFFFFFFF.FF.FFFF 095 061F38.1.00AB 00B557 ----- ------ 00042000 11111111
018F 00000EBCBCCD 00000EB6A7E0 FFFFFFFF.FF.FFFF 096 061F38.1.00AC 00C2B1 ----- ------ 00042000 11111111
0190 00000EBCBCD7 00000EB6A7E1 FFFFFFFF.FF.FFFF 09F 061F38.1.00AD 00D00B ----- ------ 00042000 11111111
0191 00000EBCBCD8 00000EB6A7E2 FFFFFFFF.FF.FFFF 0A0 061F38.1.00AE 00DD65 ----- ------ 00042000 11111111
0192 00000EBCBCD9 00000EB6A7E3 FFFFFFFF.FF.FFFF 0A0 061F38.1.00AF 00EABF ----- ------ 00042000 11111111
0193 00000EBCBCDA 00000EB6A7E4 FFFFFFFF.FF.FFFF 0A1 061F38.1.00B0 00F819 ----- ------ 00042000 11111111
0194 00000EBCBCE5 00000EB6A7E5 FFFFFFFF.FF.FFFF 0AB 061F38.1.00B1 010573 ----- ------ 00042000 11111111
0195 00000EBCBCE6 00000EB6A7E6 FFFFFFFF.FF.FFFF 0AC 061F38.1.00B2 0112CD ----- ------ 00042000 11111111
0196 00000EBCBCE7 00000EB6A7E7 FFFFFFFF.FF.FFFF 0AD 061F38.1.00B3 012027 ----- ------ 00042000 11111111
0197 00000EBCBE46 00000EB6A7E8 0612D9.1.FFFF 08D 061F38.1.00B4 012D81 ----- ------ 00042000 11111111
0198 00000EBCBE47 00000EB6A7E9 0612D9.1.FFFF 08E 061F38.1.00B5 013ADB ----- ------ 00042000 11111111
0199 00000EBCBE48 00000EB6A7EA 0612D9.1.FFFF 08F 061F38.1.00B6 0147F5 ----- ------ 00042000 11111111
019A 00000EBCBE49 00000EB6A7EB 0612D9.1.FFFF 090 061F38.1.00B7 01554F ----- ------ 00042000 11111111
019B 00000EBCBE4A 00000EB6A7EC 0612D9.1.FFFF 090 061F38.1.00B8 0162A9 ----- ------ 00042000 11111111
019C 00000EBCBE4B 00000EB6A7ED 0612D9.1.FFFF 091 061F38.1.00B9 017003 ----- ------ 00042000 11111111
019D 00000EBCBFC7 00000EB6A7EE 0612DA.1.FFFF 08B 061F38.1.00BA 017D5D ----- ------ 00042000 11111111
019E 00000EBCBFC8 00000EB6A7EF 0612DA.1.FFFF 08C 061F38.1.00BB 018AB7 ----- ------ 00042000 11111111
019F 00000EBCBFD4 00000EB6A7F0 0612DA.1.FFFF 097 061F38.1.00BC 019811 ----- ------ 00042000 11111111
01A0 00000EBCBFD5 00000EB6A7F1 0612DA.1.FFFF 097 061F38.1.00BD 01A56B ----- ------ 00042000 11111111
01A1 00000EBCBFD6 00000EB6A7F2 0612DA.1.FFFF 098 061F38.1.00BE 01B2C5 ----- ------ 00042000 11111111
01A2 00000EBCBFD7 00000EB6A7F3 0612DA.1.FFFF 099 061F38.1.00BF 01C01F ----- ------ 00042000 11111111
01A3 00000EBCBFD8 00000EB6A7F4 0612DA.1.FFFF 09A 061F38.1.00C0 01CD7F ----- ------ 00042000 11111111
01A4 00000EBCBFE2 00000EB6A7F5 0612DA.1.FFFF 0A3 061F38.1.00C1 01DA99 ----- ------ 00042000 11111111
01A5 00000EBCBFE3 00000EB6A7F6 0612DA.1.FFFF 0A4 061F38.1.00C2 01E7F3 ----- ------ 00042000 11111111
01A6 00000EBCBFE4 00000EB6A7F7 0612DA.1.FFFF 0A5 061F38.1.00C3 01F54D ----- ------ 00042000 11111111
01A7 00000EBCBFE5 00000EB6A7F8 0612DA.1.FFFF 0A6 061F38.1.00C4 0202A7 ----- ------ 00042000 11111111
01A8 00000EBCBFE6 00000EB6A7F9 0612DA.1.FFFF 0A6 061F39.1.0000 02E52F ----- ------ 00000122 00000000
01A9 00000EBCBFEF 00000EB6A7FA 0612DA.1.FFFF 0AE 061F39.1.0001 02F249 ----- ------ 00042000 11111111
01AA 00000EBCBFF0 00000EB6A7FB 0612DA.1.FFFF 0AF 061F39.1.0002 02FFA3 ----- ------ 00042000 11111111
01AB 00000EBCBFF1 00000EB6A7FC 0612DA.1.FFFF 0B0 061F39.1.0003 030CFD ----- ------ 00042000 11111111
01AC 00000EBCBFF2 00000EB6A7FD 0612DA.1.FFFF 0B1 061F39.1.0004 031A57 ----- ------ 00042000 11111111
01AD 00000EBCBFF3 00000EB6A7FE 0612DA.1.FFFF 0B2 061F39.1.0005 0327B1 ----- ------ 00042000 11111111
01AE 00000EBCBFFD 00000EB6A7FF 0612DA.1.FFFF 0BB 061F39.1.0006 03350B ----- ------ 00042000 11111111
01AF 00000EBCBFFE 00000EB6A800 0612DA.1.FFFF 0BC 061F39.1.0007 034265 ----- ------ 00042000 11111111
01B0 00000EBCBFFF 00000EB6A801 0612DA.1.FFFF 0BD 061F39.1.0008 034FBF ----- ------ 00042000 11111111
01B1 00000EBCC000 00000EB6A802 0612DA.1.FFFF 0BD 061F39.1.0009 035D19 ----- ------ 00042000 11111111
01B2 00000EBCC001 00000EB6A803 0612DA.1.FFFF 0BE 061F39.1.000A 036A73 ----- ------ 00042000 11111111
01B3 00000EBCC00B 00000EB6A804 0612DA.1.FFFF 0C7 061F39.1.000B 03778D ----- ------ 00042000 11111111
01B4 00000EBCC00C 00000EB6A805 0612DA.1.FFFF 0C8 061F39.1.000C 0384E7 ----- ------ 00042000 11111111
01B5 00000EBCC00D 00000EB6A806 0612DA.1.FFFF 0C9 061F39.1.000D 039241 ----- ------ 00042000 11111111
01B6 00000EBCC00E 00000EB6A807 0612DA.1.FFFF 0CA 061F39.1.000E 039F9B ----- ------ 00042000 11111111
01B7 00000EBCC019 00000EB6A808 0612DA.1.FFFF 0D4 061F39.1.000F 03ACF5 ----- ------ 00042000 11111111
01B8 00000EBCC01A 00000EB6A809 0612DA.1.FFFF 0D4 061F39.1.0010 03BA4F ----- ------ 00042000 11111111
01B9 00000EBCC01B 00000EB6A80A 0612DA.1.FFFF 0D5 061F39.1.0011 03C7A9 ----- ------ 00042000 11111111
01BA 00000EBCC01C 00000EB6A80B 0612DA.1.FFFF 0D6 061F39.1.0012 03D503 ----- ------ 00042000 11111111
01BB 00000EBCC026 00000EB6A80C 0612DA.1.FFFF 0DF 061F39.1.0013 03E25D ----- ------ 00042000 11111111
01BC 00000EBCC027 00000EB6A80D 0612DA.1.FFFF 0E0 061F39.1.0014 03EFB7 ----- ------ 00042000 11111111
01BD 00000EBCC028 00000EB6A80E 0612DA.1.FFFF 0E1 061F39.1.0015 03FD11 ----- ------ 00042000 11111111
01BE 00000EBCC029 00000EB6A80F 0612DA.1.FFFF 0E2 061F39.1.0016 040A2B ----- ------ 00042000 11111111
01BF 00000EBCC033 00000EB6A810 0612DA.1.FFFF 0EB 061F39.1.0017 041785 ----- ------ 00042000 11111111
01C0 00000EBCC034 00000EB6A811 0612DA.1.FFFF 0EB 061F39.1.0018 0424DF ----- ------ 00042000 11111111
01C1 00000EBCC035 00000EB6A812 0612DA.1.FFFF 0EC 061F39.1.0019 043239 ----- ------ 00042000 11111111
01C2 00000EBCC036 00000EB6A813 0612DA.1.FFFF 0ED 061F39.1.001A 043F93 ----- ------ 00042000 11111111
01C3 00000EBCC041 00000EB6A814 0612DA.1.FFFF 0F7 061F39.1.001B 044CED ----- ------ 00042000 11111111
01C4 00000EBCC042 00000EB6A815 0612DA.1.FFFF 0F8 061F39.1.001C 045A47 ----- ------ 00042000 11111111
01C5 00000EBCC043 00000EB6A816 0612DA.1.FFFF 0F9 061F39.1.001D 0467A1 ----- ------ 00042000 11111111
01C6 00000EBCC04E 00000EB6A817 0612DA.1.FFFF 102 061F39.1.001E 0474FB ----- ------ 00042000 11111111
01C7 00000EBCC04F 00000EB6A818 0612DA.1.FFFF 103 061F39.1.001F 048255 ----- ------ 00042000 11111111
01C8 00000EBCC050 00000EB6A819 0612DA.1.FFFF 104 061F39.1.0020 048FB5 ----- ------ 00042000 11111111
01C9 00000EBCC051 00000EB6A81A 0612DA.1.FFFF 105 061F39.1.0021 049CCF ----- ------ 00042000 11111111
01CA 00000EBCC05B 00000EB6A81B 0612DA.1.FFFF 110 061F39.1.0022 04AA29 ----- ------ 00042000 11111111
01CB 00000EBCC05C 00000EB6A81C 0612DA.1.FFFF 111 061F39.1.0023 04B783 ----- ------ 00042000 11111111
01CC 00000EBCC067 00000EB6A81D 0612DA.1.FFFF 11A 061F39.1.0024 04C4DD ----- ------ 00042000 11111111
01CD 00000EBCC068 00000EB6A81E 0612DA.1.FFFF 11B 061F39.1.0025 04D237 ----- ------ 00042000 11111111
01CE 00000EBCC069 00000EB6A81F 0612DA.1.FFFF 11C 061F39.1.0026 04DF91 ----- ------ 00042000 11111111
01CF 00000EBCC076 00000EB6A820 0612DA.1.FFFF 128 061F39.1.0027 04ECEB ----- ------ 00042000 11111111
01D0 00000EBCC077 00000EB6A821 0612DA.1.FFFF 128 061F39.1.0028 04FA45 ----- ------ 00042000 11111111
01D1 00000EBCC084 00000EB6A822 0612DA.1.FFFF 134 061F39.1.0029 05079F ----- ------ 00042000 11111111
01D2 00000EBCC091 00000EB6A823 0612DA.1.FFFF 13F 061F39.1.002A 0514F9 ----- ------ 00042000 11111111
01D3 00000EBCC11E 00000EB6A824 0612DB.1.FFFF 062 061F39.1.002B 052213 ----- ------ 00042000 11111111
01D4 00000EBCC11F 00000EB6A825 0612DB.1.FFFF 063 061F39.1.002C 052F6D ----- ------ 00042000 11111111
01D5 00000EBCC120 00000EB6A826 0612DB.1.FFFF 064 061F39.1.002D 053CC7 ----- ------ 00042000 11111111
01D6 00000EBCC121 00000EB6A827 0612DB.1.FFFF 065 061F39.1.002E 054A21 ----- ------ 00042000 11111111
01D7 00000EBCC138 00000EB6A828 0612DB.1.FFFF 07B 061F39.1.002F 05577B ----- ------ 00042000 11111111
01D8 00000EBCC139 00000EB6A829 0612DB.1.FFFF 07C 061F39.1.0030 0564D5 ----- ------ 00042000 11111111
01D9 00000EBCC13A 00000EB6A82A 0612DB.1.FFFF 07D 061F39.1.0031 05722F ----- ------ 00042000 11111111
01DA 00000EBCC13B 00000EB6A82B 0612DB.1.FFFF 07E 061F39.1.0032 057F89 ----- ------ 00042000 11111111
01DB 00000EBCC13C 00000EB6A82C 0612DB.1.FFFF 07F 061F39.1.0033 058CE3 ----- ------ 00042000 11111111
01DC 00000EBCC149 00000EB6A82D 0612DB.1.FFFF 08A 061F39.1.0034 059A3D ----- ------ 00042000 11111111
01DD 00000EBCC2E1 00000EB6A82E 0612DC.1.FFFF 09D 061F39.1.0035 05A797 ----- ------ 00042000 11111111
01DE 00000EBCD6D3 00000EB6A83A 0612E8.1.FFFF 0BC 061F39.1.0041 064755 ----- ------ 00002600 11111111
01DF 00000EBCD6D4 00000EB6A83B 0612E8.1.FFFF 0BD 061F39.1.0042 0654AF ----- ------ 00002610 11111111
F3 T>V40
HighPowerMode
XI2
TCC:0025:003CStatus 0001 Req 0002Nonresident GList 12 entries returned
Total entries available: 12
0 46BCC 40 0 0 0 3
1A1FE4 410FA 40 0 1 0 8DAB3
5A013A5 172 0 1F01D 1 0 4D7C3
60265B0 162 0 210FB 1 0 78CF3
8132F19 151 0 2DBA9 1 0 E5E34
8B44014 148 0 317D8 1 0 E577
94EC6CA 13E 0 3558B 1 0 CDF53
955F53A 13E 0 35B53 1 0 E4393
9F8C920 132 0 3A3F2 1 0 788AF
A20BCEC 122 0 3B31E 1 0 C2E95
A21AD14 122 0 3B3F2 1 0 AE875
AA8B30C 124 0 3EC7C 1 0 17096
AAD791E 122 0 3F0AF 1 0 CF697
AE0599F 11F 0 4084B 1 0 2FD10
AE59554 11F 0 40CF6 1 0 819B2
BA1F687 10F 0 46C92 1 0 C9593
DE9C738 D9 0 5977B 1 0 1BCFB
E35DE3B CF 0 5C614 1 0 42064
F3 T>
PrgF
Don't know how to safetly proceed to read customer user datas.
Can someone help me?
Best regards
SLAB_TEAM0
Re: Rosewood drive, media cache and LED:0x000000BD FAddr:0x0000599A problem
Postby SLAB_TEAM0 » 17.08.20, 19:35
Case solved, 100% data recovered!
Best regards
sempre
Postby sempre » 20.08.20, 16:01
SLAB_TEAM0 wrote:Case solved, 100% data recovered!
Best regards
HI !
Sorry, please how did you solve it?
nothing is impossible!
Spark
Postby Spark » 14.09.20, 17:02
SLAB_TEAM0 wrote:Source of the post Case solved, 100% data recovered!
Best regards
You have been helped, it would be polite to answer those who asked you how you solved
SLAB_TEAM0
Postby SLAB_TEAM0 » 15.09.20, 18:17
Spark wrote:Source of the post
Best regards
Sorry guys, i'm happy to help you but I have been really busy for days and have not entered forum.
So I just regen translator via terminal preserving NRG-list (be carefull if you have some of it ) and then rewrite back original translator module
I did this and it works but I have some doubts that I simply could have flushed MC via terminal and that write back that module.
That's all. Hope it can help you too. :wave:
Maxim_TS
Postby Maxim_TS » 25.09.20, 20:10
The translator regeneration makes any data in Media Cache unavailable even after the original translator writing back.
There may be no important data stored in MediaCache, and in such cases the regeneration will help to get access to the rest HDD, so it may be useful to check MCMT container before the regeneration.
Better contact us at ts.acelab.eu.com first.
