Data cant be decrypted in DE Task
murtazabawa
Postby murtazabawa » 01.07.20, 12:23
I have WD Hubble 500GB WDC WD5000LMVW-11VEDS3 drive. All essential modules are ok. But 33 plist on head0 is bad in zeros.
1. Can I reduce its size in dir editor?
2. Sectors are not accessible without using utility. I can decrypt and access sectors in utility by using "use utility" option. But in DE task I can only access sectors but its not getting decrypted. What could be the issue?
Best Regards,
Murtaza
Data Recovery Dubai
Doomer
Re: Data cant be decrypted in DE Task
Postby Doomer » 01.07.20, 18:33
1. you can but P-List is not read by the drive during the boot process and not needed for normal work
2. you drive did not boot properly that's why you cannot read sectors normally
