WHICH CONTROLLER MATCHES -SONY8GB Topic is solved
Typical Flash recovery cases
CS DATA RECOVERY
Postby CS DATA RECOVERY » 11.06.20, 18:34
Dear Seniors,
i have sony 8gb flash i cant identify matching controller any one help i search in web its broadway make.
chip id -(ID EXT= 0xADDE94EB 7444ADDE)
controller - MB GL825CL
Pavan
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Re: WHICH CONTROLLER MATCHES -SONY8GB  Topic is solved
Postby Roman_TS » 12.06.20, 11:06
Hello. We never meet this CPU before, but it will be interesting to analyze the dumps. Please read the NAND and make a ticket in our ticket system. Our engineers will guide you with this case.
CS DATA RECOVERY
Postby CS DATA RECOVERY » 12.06.20, 12:32
Dear Roman Sir,
Thanks for reply sir i will make a ticket ...
Pavan.
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Postby Amarbir[CDR-Labs] » 16.06.20, 20:04
Pavan ,
I Would Like To Work On This Case Free Of Cost For You ,Can You Send It Over To Me ,I Will Love It If You Do ,Might be i can share dump with roman then :D
CS DATA RECOVERY
Postby CS DATA RECOVERY » 17.06.20, 15:05
Dear Amarbir,
Thanks for offer sir this case no xor and no ecc found and client doesn't give time to me case was returned .
Pavan.
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Postby Amarbir[CDR-Labs] » 22.06.21, 17:13
Hi Roman ,
I have This Exact Case Now in My Hand ,Would Share Photos And Dump If You Guys Wanna Check This Out ,These Are The Details
MCU : MB GL825CL
PCB : MBIL 1PMAQ1TM Ver 1.0
NAND : Dynet D27UCG8T2ATR 64GB
NAND Details : 1x1 ADDE94DA 74C4ADDE, part size=8192Mb, page size=8832 bytes, block size=256 pages
Postby Amarbir[CDR-Labs] » 23.06.21, 10:09
Roman ,
I will be adding some pictures i took to this thread today
CDRLabs Datarecovery - MB GL825CL Genesis Logic MCU 8GB Pendrive Photo Outer Side.jpg
CDRLabs Datarecovery - MB GL825CL Genesis Logic MCU 8GB Pendrive Photo Outer Side.jpg (256.1 KiB) Viewed 160278 times
CDRLabs Datarecovery - MB GL825CL Genesis Logic MCU 8GB Pendrive Photo NAND Side.jpg
CDRLabs Datarecovery - MB GL825CL Genesis Logic MCU 8GB Pendrive Photo NAND Side.jpg (220.98 KiB) Viewed 160278 times
CDRLabs Datarecovery - MB GL825CL Genesis Logic MCU 8GB Pendrive Photo.jpg (154.28 KiB) Viewed 160278 times
PS : So if Anyone Has Working Pendrive of This Type Please Send Me a PM
