A little problem
eros86
A little problem
Postby eros86 » 09.05.20, 15:35
I have a Seagate ST3500320AS from some computer shop, standard computer was freezeing. I have done almost complete image of drive - Can't image 377080 sectors. After copying folders from chains most of them works fine but one of folder (220GB) structure don't work, all files are visible but they have lba from to lba to sector chain empty.
What can I do to make it work?
d_d_recovery
Re: A little problem with Data Extractor
Postby d_d_recovery » 09.05.20, 16:57
These files are stored in OneDrive, not on the clients PC.
eros86
Postby eros86 » 10.05.20, 09:49
d_d_recovery wrote:Source of the post These files are stored in OneDrive, not on the clients PC.
I'm not so sure because they have physical capacity, why would they have normal size if they would be stored in OneDrive only?
shahi
Postby shahi » 14.05.20, 16:15
eros86 wrote:Source of the post
The files are allowed to be saved in local drive also, that should be the reason of physical existence
Nick_TS
Postby Nick_TS » 21.05.20, 09:09
Looks like they are sparse files.
Return to “Data Extractor”
