I've a st3500820as sd81 (moose 27) with no spin and led:000000ce (sometimes cc) issue.
Sorry but I'm a newbie, so have patience.
When I power on, it tries (with a vibration) to spin up and keep trying ...but nothing.
After 30s ( about 15 vibrations) I turn it off to preserve...
1)I can access terminal
Code: Select all
LED:000000CE FAddr:0028E257
2)I can save Rom file with boot code
Code: Select all
ROM Type: 0x00(STM)
ROM Size: 0x80000
WARNING!
In Boot Code mode HDD have shortened commands set!
For full-mode work via utility you have to switch HDD power supply OFF/ON!
3)I tested resistence values in spindle contacts (about 2.8ohm)
4)I've tried this solution from ACE ... with spindle isolation but fails while spinnig up
https://www.youtube.com/watch?v=kCXDAgQMA_U
Code: Select all
Test : Solution for the "HDD Lock (LED: 000000CC)" problem
Switching HDD power supply ON
COM port reconnection...
Spin Up...
Error spinning up HDD via terminal!
Error : Terminal : reply timeout error
HDD Redynes timeout (10000)
5)So I tried ...
- - spindle isolation
- power on
- utility
- on terminal ctrl+z
- F3 T>/2
- F3 2>Z
Spin Down Complete
Elapsed Time 0.140 msecs
- remove isolation
- F3 2>U
but now terminal stucks...no reply
Code: Select all
Error 100A DETSEC 00007001
Can you help me?
