How to recover a faked SD 8.0 GB but memory chip 4GB?
Typical Flash recovery cases
oldman
Postby oldman » 27.02.20, 23:31
SD card is 8GB, but the memory HY27UV08BG5M is 4GB, only one chip,
PC3000 flash read out 2 CE, each 2GB
ID: AD D5 55 A5
No name for the controller.
Thanks.
Philip
oldman
Re: How to recover a faked SD 8.0 GB but memory chip 4GB?
Postby oldman » 27.02.20, 23:34
datasheet
HY27UV08BG5M-HynixSemiconductor.pdf
(327.27 KiB) Downloaded 488 times
Postby Roman_TS » 28.02.20, 07:37
oldman wrote:Source of the post SD card is 8GB, but the memory HY27UV08BG5M is 4GB, only one chip,
ID: AD D5 55 A5
Hello Philip. Please make a ticket in TS.acelab.eu.com, we will help you with recovery.
Postby Roman_TS » 21.03.20, 22:51
Case was recovered in ACELab ticket system. :thumbup:
oldman
Postby oldman » 26.03.20, 00:56
It works, thank to Roman :thumbup: , great helped. :D :D
