Hello. im working on a WD wd5000lmvw and when im trying to upload dir into ram i got error on modul 2
Pictures attatch.
Any advice for moving on..
WDC WD5000LMVW-11VEDS0 module 2 error
- Freakazoid
- d_d_recovery
- User
Re: WDC WD5000LMVW-11VEDS0 module 2 error
I presume you are trying to upload it from the drive?
If so, you need to find a donor, the original loader will not work.
- Freakazoid
d_d_recovery wrote:Source of the post I presume you are trying to upload it from the drive?
It is from the "load from file" from the hard drive when the hard drive was alive. I took a backup of SA. When I worked on it yesterday it works when I upload module 2 from file. But when i make imag of the hard drive it died, so today I cleaned my head. It starts up, but as mentioned, will not upload module 2.
- d_d_recovery
- User
Did you try a matching loader from a donor? ie not the original.
- Freakazoid
d_d_recovery wrote:Source of the post Did you try a matching loader from a donor? ie not the original.
Yes with same result.
- d_d_recovery
- User
Did you load the directory?
Upload DIR and LDR without 02, restart in normal and check SA - maybe module 02 is damaged
- d_d_recovery
- User
Freakazoid wrote:Source of the post But when i make imag of the hard drive it died, so today I cleaned my head. It starts up, but as mentioned, will not upload module 2.
So the heads failed while imaging the drive?
So you just cleaned them and put them back in?
Have you tried donor heads?
- Freakazoid
d_d_recovery wrote:Source of the postFreakazoid wrote:Source of the post But when i make imag of the hard drive it died, so today I cleaned my head. It starts up, but as mentioned, will not upload module 2.
I will see if i have any more donor drive for swap head and see what happen.
