Good Evening,
iam A Beginner,
Now the issue is with
Seagate 500 Gb ST3500414CS HDD redynes Error
in terminal it is showing this message
i tried with Rom Unlock But No Use
LED:000000CD FAddr:00006907
Please Help,
TEMINAL FILE:
Rst 0x10M
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Input Command Error
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Input Command Error
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
- computershopee
Srinivas
Computer shopee Data Recovery
Re: Seagate 500 Gb ST3500414CS HDD redynes Error
Hello. ACELab does not provide full technical support help in forum. If you want to solve your problem, better to create a ticket in our system. Then - engineers will guide you.
- computershopee
SOLVED BY VIKASH SETH
Thanq Sir
Thanq Sir
Srinivas
