SSD Sata adapter
Cesarj
SSD Sata adapter
Postby Cesarj » 08.01.20, 22:40
What Sata adapter do you recommend for this SSD transcend ts512gmte110s?
ssd pci.png (4.84 KiB) Viewed 5860 times
SGdata
Re: SSD Sata adapter
Postby SGdata » 09.01.20, 07:21
There's no SATA adapter for NVMe. Only USB
Cesarj
Postby Cesarj » 09.01.20, 14:44
Can you work with this USB adapter in PC3k Flash for data recovery?
d_d_recovery
Postby d_d_recovery » 09.01.20, 14:52
Only if the drive can be seen.
northwind
Postby northwind » 09.01.20, 14:53
And you can work with it in PC3000 Express if you use the power adapter by Ace.
Cesarj
Postby Cesarj » 09.01.20, 15:08
At this moment I have PC3k Flash, My PC has M2 Port to connect the SSD; I connect the SSD finds the device but it asks me for the drivers for windows 7 and it can't find them.
Now I don't know if through this port we can recover or work on it with firmware repair or logical processes?
What do they tell me?
d_d_recovery
Postby d_d_recovery » 09.01.20, 15:14
One of the best traits of a data recovery engineer is to know when to refer a job out.
I am sure you are experienced in other forms of data recovery, but perhaps this is a job for someone who has the correct equipment and experience.
Protecting the clients data is the most important thing.
Return to “Other SSD”
