I got this error opening an existing task
Error: TTask.Create - Create Drive - dmTask_4.Transaction :Transaction is not active
It doesn't change restart the utility or downgrade to a lower version.
Source drive is a USB WD
What the message mean?
Thank you all
DE error opening an existing task
Re: DE error opening an existing task
Problem solved.
Moving (not copy) the task to another disk with total commander get "Please remove the write protection!"
On source disk there isn't in explorer the "CUT" option so I just copied it (not moved) to another disk
Now task opens regularly and i'm doing research on the problem related with this unit.
same problem and had to start image process again.
Let me tell you the error. image process is over, I saw the folders, I scanned mft+indx process was finished then DE gave error and then the task was not opened again.
The problem is how the task was created without saving sectors and then it was not connected.
