Anyone had anyluck using the PC3K/DE for NVME SSD drives??
Is it pointless to get a USB adapter and attempt to use DE in any way for recovery of an NVME drive?
- d_d_recovery
- User
Re: Anyone had anyluck using the PC3K/DE for NVME SSD drives??
I believe Ace are about to launch a new tool aimed exactly at these drives.
I contacted them and they didn't mention anything. A time frame would be great.
- digitalsupport
- User
In October Roman teased it as "in future" and November as "You even can't imagine how close this news to our news line"
https://forum.acelab.eu.com/viewtop ... 179&t=9888
I've used the DeepSpar USB Stabilizer and a USB NVME adapter to image then recover the data from one. Worked a treat!
- d_d_recovery
- User
I have the Deepspar PCIe DDI, but have had very mixed success.
- digitalsupport
- User
Have used USB to NVMe and PCI-e adapters, modified with DE power control and in circuit power adjustments with mixed success.
But when (not if) memory degrades and errors blocks the drive from init, there is little to do.
Thanks for the responses.
LarrySabo wrote:Source of the post Have used USB to NVMe and PCI-e adapters, modified with DE power control and in circuit power adjustments with mixed success.
I, too, have had some pretty good success with the DeepSpar USB Stabilizer in tandem with DE. Unfortunately, in cases where the translator is toast, there isn't much that can be done with commercially available tools.
Not that it matters Luke, but that was @digitalsupport you quoted, not me.
