Urgent: Sandisk Extreme 32GB 60mb/s
pad-dataservice
Postby pad-dataservice » 01.12.19, 17:14
I have an urgent case and hit a wall.
Monolith has been read with some errors. XOR is 1872
Chip ID 0x453CA593 1 part
7E500C04, part size=32768Mb, page size=17664 bytes, block size=256 pages
Marking on monolith 5266DEJ23394 032G
Anyone has a solution for this or are willing to give it a try?
best regards
Michael
Re: Urgent: Sandisk Extreme 32GB 60mb/s
Postby Roman_TS » 02.12.19, 06:31
ACELab TS can provide you a solution. But you should make a ticket in our TS system.
ACELab does not provide TS help in forum. If you want to solve your case and get a solution - you need to submit a ticket.
pad-dataservice
Postby pad-dataservice » 02.12.19, 10:07
Hi Roman
Yes i know :) But it was after hours, so I was hoping for someone out there in a different timezone... and that was online on a sunday ;)
Postby Roman_TS » 02.12.19, 11:18
Sometime we check tickets even on weekend :)
lcoughey
Postby lcoughey » 02.12.19, 13:56
Probably a good practice is to create the ticket right away and then look for solutions while you wait for a response from ACE.
