ST2000LM007 (100790701) PCB SHORTENING POINTS
ddcywf
Postby ddcywf » 18.09.19, 09:21
Kindly help in finding the ST2000LM007 (100790701) PCB shortening points.. thanks
Re: ST2000LM007 (100790701) PCB SHORTENING POINTS
Postby digitalsupport » 18.09.19, 13:06
Maybe tell a little more about the drive, why you want to "short" it.
How is the drive behaving, any hints in terminal, what happened and what has been done ?
Have done many Rosewood drives but never had the need to "short" any.
northwind
Postby northwind » 19.09.19, 10:20
digitalsupport wrote:Source of the post Maybe tell a little more about the drive, why you want to "short" it.
Completely agree.
ddcywf
Postby ddcywf » 20.09.19, 07:19
The drive giving clicking noise and not getting out of BSY state.
northwind
Postby northwind » 20.09.19, 11:37
terminal?
cmy2008
Postby cmy2008 » 23.09.19, 05:42
This short connection doesn't make any sense! T can be obtained directly.
Paradog84
Postby Paradog84 » 24.09.19, 17:48
Just want to add to this, I myself have shorted a few Rosewoods and had good results - again the key is making sense of what is happening in terminal and of course when to do it.
I agree with digitalsupport - you shouldn't need to short any if the heads are good, but in a few cases it is needed
GuideRecovery
Postby GuideRecovery » 27.09.19, 10:28
ddcywf wrote:Source of the post Kindly help in finding the ST2000LM007 (100790701) PCB shortening points.. thanks
share terminal log, may be it is not necessary to short read channels at all !
Wasim Zafar
https://mindmergepk.com
