Rosewood , FW: SDM 2 . no ID and Capacity.
betty
Postby betty » 11.08.19, 14:21
hello to all,
I hv one 1tb Seag Mobile hdd family :Rosewood , FW: SDM 2 .
Smooth spinning, module can access... But no ID and Capacity....i tried to remove the background process from 93h... no luck... showing error in terminal
" Unsupported FW"
I tried translator regen ,after taking and imp system files... its completed successfully , but no luck no ID& Capacity .
I marked one thing, when ever its giving error ,the status register blinks with DSC DWG DRD also AMN & ERR
Any one have the same experience, please share any solution
SGdata
Re: Rosewood , FW: SDM 2 . no ID and Capacity.
Postby SGdata » 11.08.19, 15:04
Did you write 93 via terminal or indirect?
Postby digitalsupport » 11.08.19, 18:51
Try to disable idle activity via terminal
hdd00
Postby hdd00 » 12.08.19, 05:13
Most likely the drive have corrupted/unreadable MC table module......Try to correct that.
betty
Postby betty » 13.08.19, 07:13
SGdata wrote:Did you write 93 via terminal or indirect?
Can you provide terminal command for modification of 93
thanks
SGdata
Postby SGdata » 13.08.19, 07:49
lka124
Postby lka124 » 13.08.19, 12:05
betty wrote:Source of the post I tried translator regen ,after taking and imp system files... its completed successfully , but no luck no ID& Capacity .
from Blog about that: DO NOT regenerate the translator on Rosewood family.
Paradog84
Postby Paradog84 » 13.08.19, 15:26
Backup important files via terminal (93, 1B, 28, 346 & 348)
Then flush MC from /C level in terminal using command "U10"
betty
Postby betty » 14.08.19, 16:28
Paradog84 wrote:Backup important files via terminal (93, 1B, 28, 346 & 348)
thanks to all
AYNIADAM
Postby AYNIADAM » 16.10.19, 20:23
I get the same error rosewood. Abr problem. terminal connected. translator backup. Is there a solution to this error?
AYNIADAM
Postby AYNIADAM » 26.10.19, 19:44
I still haven't found a solution. please help me.
