Hi there,
I have a seagate that will not detect correctly. I think that the logic board may not be original so I want to run a terminal command to read the serial number from the pcb. (ST3500418AS)
I have tried the following commands but cannot see anything that looks like the serial in the results:
Ctrl + a (displays drive info, Package Version, Serial #, Model # (useful for missing label), Servo FW, etc.
Ctrl + l (displays drive info, # heads, serial, preamp type, family ID, etc.)
Results below, am I missing something? sureely it sould be fairly straight forward to return the serial number?
F3 T>
Package Version: PH0GCD.HPD1.EG036J., Package P/N: 100610824, Package Builder ID: AT,
Package Build Date: 01/12/2010, Package Build Time: 14:57:02, Package CFW Version: PH0G.HPD1.00233047.AT00,
Package SFW1 Version: DC66, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 01121457, CustomerRel: HP34, Changelist: 00233047, ProdType: PH0G.HPD1, Date: 01/12/2010, Time: 145702, UserId: 00236537
Servo FW Rev: DC66
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03
ASCII Diag mode
F3 T>
YetiST Rev: 649B; CurSpd: 3.0Gb; SpdLimit: No; SSC: No; LED: No; StagSpinByp: Yes;
SATA Block Registers
ATA
400A0000: 0000 0000 0000 0000 0000 0000 0000 0000
400A0010: 0000 0000 0000 0080 0040 0000 0000 0400
400A0020: 0100 0000 0010 0210 0000 0000 0000 0000
400A0030: 0010 8403 0000 0000 0000 0000 0000 0000
400A0040: 0000 0000 0000 0000 0000 0000 0000 0000
400A0050: 0000 0000 0000 0000 0000 0000 0000 0000
400A0060: 0001 0000 0000 0000 0000 0000 0000 0000
400A0070: 0000 0001 0000 0000 0000 0000 0000 0000
400A0080: 0000 0000 0001 0001 0000 0000 0000 0080
400A0090: 0001 0000 0000 0000 0000 0000 0000 0000
400A00A0: 0000 0000 0000 0000 0000 0000 0000 0000
400A00B0: 0000 0000 0000 0000 0000 0000 0000 0000
400A00C0: 0000 0000 0000 0000 0000 0000 0000 0000
400A00D0: FFFF FFFF FFFF FFFF 0000 0000 0000 0000
400A00E0: 0000 0000 0000 0000 0000 0000 0000 0000
400A00F0: 0000 0000 0000 0000 0000 0000 0000 0003
SATA Global
400A0100: 0000 0000 0000
Link Layer
400A0130: 0000 0000 0000 0000 8000 0000 0F00 0000
400A0140: 0020 0013 0000 0000 0000 0000 0000 0000
400A0150: 0000 0000 0001 0000 0000 0000 0000 0000
400A0160: 0000 0000 0000 0000 0000 0000 0000 0000
400A0170: 0000 0000 0000 0000 0000 0000 0000 0000
400A0180: 0000 0000 0000 0000 0000 0000 0000 0000
400A0190: 0000 0000 0000 0000 0000 0000 0000 0000
400A01A0: 0000 0000 0000 0000 0000 0000 0000 0000
400A01B0: 0000 0000 0000 0000 0000 0000 0000 0000
400A01C0: 0000 0000 0000 0000 0000 0000 0000 0000
400A01D0: 0000 0000 0000 0000 0000 0000 0000 0000
400A01E0: 0000 0000 0000 5032 5232 5032 5232 0000
400A01F0: 0000 0000 0000 0000 0000 0000 0000 0000
Transport Layer
400A0250: xxxx xxxx xxxx xxxx xxxx xxxx 0000 000F
400A0260: 0000 0000 DCE8 7D7D 0000 0020 0000 3018
400A0270: 0000 0000 0000 0000 0000 0000 0000 0000
400A0280: 0000 0000 0000 0000 0000 0000 0000 0000
400A0290: 0000 0000
NCQ Cmd Validation
400A0300: 0000 0000 0000 0000 0000 0001 0000 0000
Application Layer
400A0390: xxxx xxxx xxxx xxxx 0000 2500 0000 5058
Shadow Task File
400A03A0: xxxx xxxx 0000 0000 0000 0000 0000 0000
400A03B0: 0000 0000 0000 0000 0000 0000 0000 0000
400A03C0: 0000 0000 0000 0000 0000 0000 0000 0000
400A03D0: 0000 0000 0000 0000 0000 0000 0000 0000
400A03E0: 0000 0000 0000 0000 0000 0000 0000 0000
400A03F0: 0000 0000 0200 0000
PhyPM Regs
400A0700: 0000 000F 0000 0001 0010 0000 0000 0000
400A0710: 0000 0000 0000 0000 0000 0000 0000 0000
400A0720: FFFF FFFF FFFF FFFF 0000
Physical Layer
400A0800: 0000 0000 0001 9123 0000 0000 0000 0020
400A0810: 0000 0001 0000 005D 2CC0 CBF5 9000 3333
400A0820: 364D A494 0800 96A8 1414 0274 0000 0000
400A0830: 0000 047F 0000 0000 0000 0000 0000 0000
400A0840: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
400A0850: 0000 0000 0000 0000 0000 0000 0000 0000
400A0860: 0000 0000 0000 0000 0000 0000 0000 0000
400A0870: 0000 0000 0000 0000 0000 0000 0000 0000
400A0880: 0000 0000 0000 0000 0000 0000 0000 0000
400A0890: 0000 0000 0000 0000 0000 0000 0000 0000
400A08A0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08B0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08C0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08D0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08E0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08F0: 0000 0000 0000 0000 0000 7878 7878 0000
SATA Visibility Mux
400A02E0: xxxx xxxx xxxx xxxx xxxx xxxx 0000 0000
400A02F0: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Layers Diag Mux
400A0EF0: xxxx xxxx xxxx xxxx xxxx xxxx 0000 0000
400A0F00: 0007 0000 0000 0000 0000 0000
Shanghai390 Phy Registers
TX
8000: 10 00 00 25 01 03 01 00 00 04 00 00 07 FF 07 80
8010: 00
RX
8600: 00 00 00 65 40 18 00 29 30 02 14 00 10 00 A0 12
8610: 00 00 00 00 00 0C B1 82 D4 FC A8 00 00 00 01 7C
8620: 83 FF 40 00 05 00 00 05 00 00 00
MCTL
8700: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8710: 01 00 00 00 00 00 00 00 00 00 00
AFE
8800: 18 05 08 00 00 13 04 0F 09 08 00 00 30 18 0A 00
8810: 18 05 00 01
SIF
C000: 08 00 00 00 05 00 07
Wrapper
C100: 02 00 C7 00 00 67 00 00 00 04
PatGen
D000: 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D010: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
D020: 55 55 55 55
CMU
F000: 73 28 00 2E 01 00 85 85 85 00 F4 39 0C 50 68 01
F010: 01 00 17 00 00 7F 1C 20 00 00 3D 3D 3D 00
VBM Cache Search Registers
40012680: 0000 0000 0000 0000 007F 0000 0000 00FF
40012690: 0000 0000 0000 0000 0000 0000 0000 0000
Traverser Regs
40012700: 0000 0000 0000
Host Data Manager Regs Bank 0
40012800: 0007 0000 7FFF 0000 0000 0000 0000 0000
40012810: 0000 0000 0000 0000 0000 0000 0000 0000
Disc Data Manager Registers Bank 0
40012900: 0FA7 0008 0088 0000 0088 0000 0088 0000
40012910: 0088 0000 0088 0000 0088 0000 0088 0000
PBM Memory Controller Registers
40012A00: 0090 000B 0008 0235 0033 4002 0029 4423
40012A10: 00A4 E600 E600 0090 0090 0000 0000 0000
40012A20: 0000 0000 0000 0000 0000 0000 0000 0000
40012A30: 2F00 0004 FFF7 000A FFFF 07FF 0000 0000
40012A40: FFFF 07FF 0000 0000 FFFF 07FF 0000 0000
40012A50: 0000 0000 6B82 0500 B026 9004 0DC8 300A
40012A60: 0000 0000 0000 0000 0000 0000 0000 0000
40012A70: 0000 0000 0025 0000 0000 0000 0000 0000
FDE Block
40012B00: 0000 0000 0000 0000 0000 0000 0000 0000
40012B10: 0000 0000 0000 0000 0000 0000 0000 0000
40012B20: 0200 20F0 FD5E 00BD 16E5 49B6 0000 0000
40012B30: 0000 0000 0000 0000 0000 0000 0000 0000
Hardware Phy Event Counters
00000000: 0000 0000 0000 0000 0000 0000 0000 0000
00000010: 0000 0000 0000 0000 0000 0000
R_ERR on RX FIS Non-data: 00000, Data: 00000
R_ERR on TX FIS Non-data: 00000, Data: 00000
terminal command to get drives serial number
Re: terminal command to get drives serial number
Just read the ROM and all the info can be displayed with one of the buttons there.
Ah, thanks very much! Got it. cheers
Ctrl+\ should show you what you want
yes thats returned the serial. Thanks Doomer
