NV-RAM Recovery- HTS725032A9A364
d_d_recovery
Postby d_d_recovery » 20.06.19, 16:30
This drive had a corrupt NV-RAM and bad heads. New heads installed and I am using a donor board (same board #). I have tried recovering the NV-RAM as described in the manual, which worked, however the recovered NV-RAM does not work. On comparing the NV-RAMs I see the recovered NV-RAM has the same SN as the donor board. Is that correct? Just wondering if something when wrong with recovering it.
