pin out
codice pin
pin out
Postby codice pin » 29.04.19, 14:40
I can't find the points of this samsung 32gb
Re: pin out
Postby Roman_TS » 30.04.19, 23:22
We have this pinout, but recovery of this mSD is impossible due the adaptive XOR. Even if you will read it, complete recovery will be impossible.
codice pin
Re: pin out
Postby codice pin » 02.05.19, 17:31
can I have it? I want to do cross-tests with other tools
Re: pin out
Postby Roman_TS » 02.05.19, 21:12
Nobody can beat this adaptive XOR, even other tools ;) But you can PM me, I will reply you in next Monday.
Multi-COM
Re: pin out
Postby Multi-COM » 03.05.19, 15:57
@codice pin: Those Samsung cards uses a cipher with a rotating key which is based on LBA so as Roman write you will not recover data from it unless you will get correct key from Samsung.
Boguslaw Rzepka
http://multi-com.eu
codice pin
Re: pin out
Postby codice pin » 06.05.19, 17:38
I trust what you tell me, I still wanted to dump and try, but I can't find the right points and apparently nobody has them
Paulsen
Re: pin out
Postby Paulsen » 12.09.19, 10:11
I got a Sony mSD with the same layout. Do you know if they also use an adaptive XOR, or could a recovery be possible?
