ST3000DM001
CIEL
ST3000DM001
Postby CIEL » 14.03.19, 11:08
I need some help with this drive ST3000DM001 FW:CC46 P/N:1ER166-570 DATE:09AUG2017. This drive have a problems of heads, but I have baout 3 months waiting for buy a donor on Ebay or Donnor Drive but theres is not have any otrehr drive like this, I just want to know if someone have a drive like this or know some compatibility whit other donor drive.
Thanks and best regards
lcoughey
Re: ST3000DM001
Postby lcoughey » 14.03.19, 13:37
If you are trying to search to the exact data, you are likely looking too hard.
ST3000DM001 and the 1st 3 digits of the SN should be enough.
CIEL
Re: ST3000DM001
Postby CIEL » 14.03.19, 15:27
lcoughey wrote:Source of the post If you are trying to search to the exact data, you are likely looking too hard.
I usually look a hdd with 3 months (up or down) of difference in the date, but even so there is not find any HDD
lcoughey
Re: ST3000DM001
Postby lcoughey » 14.03.19, 15:27
Got a picture of the top cover?
CIEL
Re: ST3000DM001
Postby CIEL » 15.03.19, 09:22
lcoughey wrote:Source of the post Got a picture of the top cover?
This is the HDD
Thanks for your help
lcoughey
Re: ST3000DM001
Postby lcoughey » 15.03.19, 10:53
Matching the model and first 3 digits of SN, I have 2 listed here:
https://hddstockroom.com/catalog/?search=Z50
CIEL
Re: ST3000DM001
Postby CIEL » 19.03.19, 12:03
lcoughey wrote:Source of the post Matching the model and first 3 digits of SN, I have 2 listed here:
Hi lcoughey
the first number of the SN is fine but the FW and PN its not the same. I was try with a hdd just like a you send me but it is dont working, but thanks for yout help. I still looking
Thnaks and Best Regards
lcoughey
Re: ST3000DM001
Postby lcoughey » 19.03.19, 12:11
CIEL wrote:Source of the post
Hi lcoughey
Then your issue is more than heads, in my opinion. Did you try the patient heads in the donor?
CIEL
Re: ST3000DM001
Postby CIEL » 20.03.19, 16:22
lcoughey wrote:Source of the post Then your issue is more than heads, in my opinion. Did you try the patient heads in the donor?
When I receive the drive, this was has a problems that head-stack,
I was unstuck the heads with carefully and I was check the drive and the heads no work, I was try with a donor but this is not compatible,
I returned the heads to the donor and this are working fine.
You still thinking that I should be try change the heads of the patient in the donor?
lcoughey
Re: ST3000DM001
Postby lcoughey » 20.03.19, 18:06
If the patient heads work in the donor, you know both that they are compatible and that the issue must be with the firmware and/or surface.
CIEL
Re: ST3000DM001
Postby CIEL » 21.03.19, 11:05
lcoughey wrote:Source of the post If the patient heads work in the donor, you know both that they are compatible and that the issue must be with the firmware and/or surface.
I test the patient heads in the donor and doesnt work , and the drive do it the same sound 2 klicks and motor spin off.
GuideRecovery
Re: ST3000DM001
Postby GuideRecovery » 31.03.19, 12:02
Can you upload the ROM of both patient and donor to see if they are compatible or not ?
Wasim Zafar
https://mindmergepk.com
DDDRI
Re: ST3000DM001
Postby DDDRI » 08.04.19, 22:44
Did you import adaptives from the donors rom into the patients?
:wave:
Users browsing this forum: gautam.dotcom and 12 guests
