WD30NMRW-11YL9S4 Head compatibility
Rwinters
Postby Rwinters » 08.02.19, 23:42
Anyone had luck with NMVW heads in these? Tried some that I had here that seemed like they could be a good match and they aren't working, but of course work great when put back into the donor.
Re: WD30NMRW-11YL9S4 Head compatibility
Postby DataMedics » 11.02.19, 02:52
You are looking at the totally wrong part of the model. You should be focusing on the part after the dash. I've been keeping track of WD families by their codes on this page for quite some time: https://www.data-medics.com/forum/ident ... -t636.html
As you can see from my list YL9 is PebbleB family and you should be able to match from any other PebbleB model with the correct part of the DCM code, site, head map, and a close enough date.
Blizzard
Postby Blizzard » 11.02.19, 06:10
So far, I haven't seen a PebbleB or Spyglass with a DCM on the label :(
Postby DataMedics » 11.02.19, 13:37
Blizzard wrote:Source of the post So far, I haven't seen a PebbleB or Spyglass with a DCM on the label :(
That's true. My comment was more of an in-general statement. Obviously you've got to work with whatever is actually available. I don't think there's too many variations in the heads used with these newer WDs either. In more recent drives I've been finding heads from 1 to 2 years off are still working fine. So DCM is probably unnecessary to even match.
Doomer
Postby Doomer » 11.02.19, 15:17
But there are different heads nevertheless
Blizzard
Postby Blizzard » 11.02.19, 15:33
Doomer wrote:But there are different heads nevertheless
Indeed. At least RWinters won't go crazy looking for a DCM that isn't there :)
Rwinters
Postby Rwinters » 11.02.19, 17:06
Thanks for the replies, yes I am well aware of family codes, but I have had a lot of luck jumping families in the past. Yes, I did notice the DCM is gone, and ever since I have seen a DCX it seems pretty useless from what I can tell.
Anyways, I have some C3NS heads that are giving the same symptoms (3 clicks delayed between each other follow by spin down) as the patient heads YL98. Even with SA + Mod 30 blocked it wants to click and spin down? Patient heads where in pretty good shape under microscope so i dont suspect serious platter damage, the ramp did make some contact along the edge as is common with drops or rough handling of these.
Patient isn't killing parts...as they work just perfect back in their original housing.
Postby Amarbir[CDR-Labs] » 17.03.19, 20:22
Very Interesting,
Was There Any Progress In These Rwinters
Rwinters
Postby Rwinters » 29.04.19, 18:40
Sorry I totally forgot to update on this: Full recovery was achieved with a matching WD30NMRW-11YL9S4 (basically label wise, a perfect match)
