Hi @ all,
i have the Toshiba MK5075GSX whit GT001U Rom and after i boot the disk i see this:
Techno On............................... : Device Error Detected 51/04 (ABR)
Zone table.............................. : Zone table read error; Transmission data stop CMD error; Device Error Detected 51/04 (ABR)
G-List reading error.................... : G-List read error; Transmission data stop CMD error; Device Error Detected 51/04 (ABR)
CP Avalable............................. : 33,34,44,56,92,95,98,9A,9B,9C,A2,A5,A8,A9,AA,AD,AE,AF,B1,B3,B5,B6,BB,BD,C1,C4,C5,C6,C7,C8,C9,CB,CD,D0,D1,D4,D6,D7,D8,D9,DA,DB,DD,E0,E1,E2,E3,F3,F5
What can i do? I can't write a new copy of the rom because it will send me only ABR Error...
Thanks and best wishes
Luigi
Toshiba MK5075GSX - ROM Problem or Surface?
- Takanashi_Hina
Re: Toshiba MK5075GSX - ROM Problem or Surface?
Super ON is rejected so you can't do a thing with the drive.
Either it's "locked" with some sort of special firmware that does reject the standard SUPER ON or the PCB is damaged ...
Does the drive spin up at all ? Can't you access a single LBA ? Does the drive ID at least ?
So i can't see anything....
The HDD is power on and the motor is working but the head isen't starting...
Now i have change the PCB and it is the same problem....
Head swap?
Best wishes
Luigi
Head swap?
Best wishes
Luigi
- Takanashi_Hina
Strange thing is that the drive do reject the SUPER ON ...
