what chip i have to use for the donor pcb
thanks
Which chip do I have to change for the donor pcb
- tonoarimany2012
Re: Which chip do I have to change for the donor pcb
For a donor Sata Pcb , IC2 need to be changed .
- GuideRecovery
you need to change U12 only ... BTW if you have pc3000 why bother soldering.
there are other good ways to swap ROM
Wasim Zafar
https://mindmergepk.com
Wasim Zafar
U12 is a HDD ROM chip. U14 is USB bridge chip. It's better to read the ROM via COM-port, then write it to SATA PCB, this way is more safe than unsoldering.
http://blog.acelab.eu.com/boot-rom- ... rives.html
