WD5000AAKX-22ERMA0 LDR is needed
d1d
Postby d1d » 23.10.18, 20:53
Hi same,
i have a problem whit WD5000AAKX. I have changed the Head. It was totaly damanged but the Surface is ok.
So the HDD is now working but, it spins up and after 10 secondes it spins down. So i need the LDR File, is there anyone how have the data?
Thanks a lot and best wishes
Luigi
lcoughey
Re: WD5000AAKX-22ERMA0 LDR is needed
Postby lcoughey » 23.10.18, 21:01
What ROM version are you looking for?
d1d
Postby d1d » 23.10.18, 21:27
Hi Icoughey,
FW Version is 0005000K and the ROM Data is this:
HDD Identification reading ............. : Ok
View ROM information
ROM Modules
0A : Heads map
0B : Flash ROM dir
20B : Flash ROM dir (ext)
30 : SA Translator
47 : SA Adaptives
02 : Unknown module
4F : Microprogram version
SA Regions
N : ABA : Size
0 : 1 : 2 147 642 398
1 : 330 241 : 2 147 642 398
Micro Jogs
LH : PH : Micro Jog (Hex/Dec)
0 : 0 : A8A/2698
1 : 1 : B81/2945
Thanks and best wishes
Luigi
Postby AJ2008 » 24.10.18, 12:29
d1d wrote:Source of the post it spins up and after 10 secondes it spins down
I do not think LDR will help so much, though you would need LDR upload to change map of heads in RAM, but with 2 heads only this will limit access to 50% of surface. If surface is good and head replacement went well with good donor, then you should look at how well head replacement was made.
Maxim_TS
Postby Maxim_TS » 26.10.18, 15:54
d1d
Postby d1d » 08.11.18, 09:21
Hi AJ2008,
i have do it by meyself... so i can see this:
Firmware version........................ : 0005000K
ROM Modules
0A : Heads map
0B : Flash ROM dir
30 : SA Translator
47 : SA Adaptives
0D : Flash configuration
SA Regions
N : ABA : Size
0 : 0 : 158 750
1 : 330 240 : 158 750
Micro Jogs
0 : 0 : B4C/2892
1 : 1 : A8B/2699
I think the Head is working but it spins up and down....
@Maxim_TS - thanks a lot! I have write the file back but i have the same problem...
I will have a look on the PCB again....
d1d
Postby d1d » 08.11.18, 09:25
ok, so why?!?
Module ID 35 reading error Data request error Device Error Detected: "SERVO ERROR CODE BASE SvirActSync"
Module ID 01 reading error Data request error Device Error Detected: "SERVO ERROR CODE BASE SvirActSync"
Takanashi_Hina
Postby Takanashi_Hina » 08.11.18, 19:47
Heads / pre-amp are gone ... That is why you get SERVO ERROR CODE BASE SvirActSync. Even if you can load code to RAM you can't read the data on the platter without working heads and pre-amp.
d1d
Postby d1d » 09.11.18, 13:55
Hi Takanashi_Hina,
ok i understand but it was a ned Head so i have changed it back and the head is working.... so i can´t understand the problem....?!?
