So I've done several Seagate SSHD PCB replacements already and I know about how to clear the NAND to get it working after transferring the ROM. However, I've got a case here that I can't seem to find a drive that's a close enough match for the code in the NAND to work with my patient ROM code. I've tried three same model/part number/FW drives but all were manufactured 4+ months after this drive and I can't find one with a closer date.
I was told on the last post of this thread about a Ace possibly having a custom ROM that can allow for wiping the NAND: https://forum.hddguru.com/viewtopic.php ... 47#p265047
Any chance I could get my hands on that custom ROM? (I know my support is currently expired, but I'm only asking for a copy of the custom ROM code)
ST1000LM014 SSHD PCB Replacement Issues
- DataMedics
Re: ST1000LM014 SSHD PCB Replacement Issues
hello
I had some cases like this. Please check PreAmp-ID !!
Some drives looks like all the same but they have different heads and the Kahuna solution/Donor PCB will not work.
This info is stored in NAND too.
Hope it helps
By the way:
I am searching for LVD5 PCB (ST1000LM014)
Hope it helps
By the way:
- DataMedics
Even if I leave the donor PCB on the donor drive it won't attempt to spin up with the patient ROM code. So I just need to find a closer one unless someone has another solution here. Issue seems to be the firmware in the NAND won't play nice with the ROM code.
Some ROM will use CFW overlays, some will use DFW. You will need to use donor that uses corresponding type.
It may be possible to import RAP CAP SAP IAP from patient ROM into donor ROM using CFW overlays then use Kahuna patch to flush NAND.
- digitalsupport
- User
Any terminal output, Flash Led or ALFTable errors ?
Have you tried to make a hybrid rom as AJ2008 suggested ?
- DataMedics
AJ2008 wrote:Source of the post Some ROM will use CFW overlays, some will use DFW. You will need to use donor that uses corresponding type.
This was, somewhat helpful. After importing adaptives from patient ROM into donor ROM I'm able to get the drive to spin up and ID (with the Donor ID naturally) and I can even get into terminal. However, when I try to clear the NAND in terminal I get servo errors and then the drive reports:
Code: Select all
F3 O>I
RECOV Servo Op=0055 Resp=0005
RECOV Servo Op=0155 Resp=0005
Failed to load overlay 00000004
LED:000000BD FAddr:00004264
Rst 0x40M
Boot 0x40M
Spin Up
Trans.
Disc FW failed to load
(On subsequent power up)
Code: Select all
Failed to load overlay 00000001
Rst 0x40M
Boot 0x40M
Spin Up
Trans.
What's really odd is I can only get into terminal once, then on subsequent power-ups it instantly goes to the "Disk FW failed to load" error. I can only get back into terminal by writing the hybrid ROM code to the PCB again.
- DataMedics
digitalsupport wrote:Source of the post Any terminal output, Flash Led or ALFTable errors ?
The terminal error with the donor ROM is always the same:
Code: Select all
Boot 0x40M
LED:000000EE FAddr:002579E4
- DataMedics
This is the terminal message with the original PCB still in place:
Maybe I'm totally looking in the wrong place and the PCB is fine. I'm not really sure. This SSHD architecture still baffles me at times. It's not doing any clicking or making any sounds that'd indicate head failure, it's just refusing to spin up at all with the original PCB/ROM so my suspicion immediately goes to the PCB.
Code: Select all
Boot 0x40M
Trans.
ERROR: Flash Led 9C2A - ALF-SetupForComboMode Failed - Invalid Mode
Clump: FE55
Combo Mode Bit: 0002
Clump Parametrics:
Clump = 012F
DataType = 001A
ModeFlag = 01
EraseCount = 00007643
EraseFailCount = 00
ProgramFailCount = 00
WeakReadCount = 00
UncorrectableECCError = 00
---SOC PSM Command History---
Cmd#/PsmCmd Clump Offset Length LbaMid LbaLow LbaBits39To32 Options Status DestClump DestOffset
0000 012F 18C8 0000 8000 2F62 0000 C000 0080 C207 AA14
0800 012F 18C0 0008 8000 2F5A 0000 C000 0080 C207 AA14
0701 0122 16E0 0020 0000 0000 0000 C000 0080 C207 AA14
0600 0007 1520 0001 0000 0000 0000 C000 0080 C207 AA14
0501 0007 1520 0001 0000 0000 0000 C000 0080 C207 AA14
Flash Statistics:
BridgePSMDriverID = 0x0009
FlashID 98D7 8493 72D7
Flash Manufacturer: Toshiba19nm
Flash Capacity = 00008 GB MLC
Combo Mode
NumberOfClumps = 0x0400
LBAsPerCluster = 0x0020
LBAsPerClumpMLC = 0x4000
LBAsPerClumpSLC = 0x2000
ClustersPerClumpMLC = 0x0200
ClustersPerClumpSLC = 0x0100
DefragClumpThresholdInSectors = 0x2000
UserSLCMaxSizeInClumps = 0x0180
NumberOfPotentiallyWrittenClusters = 0x0002
DefectListRevisionKey 0x0002
SLC Clumps 0x01A7
ActiveClumpInfo
Active Journal Clump 0122 Offset 1700
Active Anchor Clump 0007 Offset 1520
DType 0000 Read Cache Clump 0326 Offset 0000
DType 0001 Read Boot Clump 0253 Offset 0000
DType 0008 Dirty Write Cache Clump 0173 Offset 0000
DType 0009 Dirty Boot Clump 010D Offset 0000
DType 0011 Clean Write Cache Clump 0136 Offset 0000
DType 0012 Clean Boot Clump 00C3 Offset 0000
DType 001A SIM Clump 009B Offset 0000
DType 001B DRIVEFW Clump 0101 Offset 0000
--- ALF RFS Recorder ---
--- Recorder prints backwards: newest to oldest ---
IARCount Status Clump ClumpSentinel FunctionOrigin
ALFRecorder:
TableAdjustForMoveClump
TableAdjustForMoveClumpToCondemn
GetNewActiveClump
GetNewActiveClump
ReconstructNodesInActiveClump
GetNewActiveClump
MakeAnErasedClumpAvailable
EraseCondemnedClump
EraseCondemnedClump
EraseCondemnedClump
EraseCondemnedClump
GetNewActiveClump
EraseCondemnedClump
GetNewActiveClump
EraseCondemnedClump
GetNewActiveClump
EraseCondemnedClump
GetNewActiveClump
EraseCondemnedClump
GetNewActiveClump
EraseCondemnedClump
EraseTableSystemClump
WriteALFTables
SaveNewAnchorToFlash
AdvanceActiveAnchorPointer
WriteAnchorEntry
WriteAnchorEntry
WriteJournalLog
AdvanceActiveJournalPointer
IssueALFRequest
ReadDataFromFlash
IssueALFRequest
ReadDataFromFlash
Request spin / disc table recovery
hello everyone
i have the same case
at first it was status busy and after a while changed to ready, but after i follow the topic atached here by kahuna 5400 utility, i wrote the rom and it's worsed, and now it's don't spins up anymore
i have a donor drive, i replaced the heads, my pacient heads were good because my donor runs with them normaly, but now i can't returns to initial mode because this model have a nand chip, and i don't know if i must replace pcb , it won't help without the original NAND , i think so
how do i make to returns to the first state ?
i wrote the original ROM after and it also didn't work, i think that i had a unique chance , and i wasted it
- Attachments
- HDD. SSHD LM014_compressed.pdf
- (1.21 MiB) Downloaded 239 times
after i replaced the PCB , quick data analise on pc3000, NTFS, it's worked normaly, i restore client data without none problem with nand, the nand doesn't scare me anymore
SOLVED
SOLVED
