I have problems with DATA EXTRACTOR V5.7 "Execution of all processes is aborted!"
cuumaytinh
Postby cuumaytinh » 11.10.18, 16:30
I have problems with DATA EXTRACTOR V 5.7.8
When I create the image. in the process of running a lot of times the process stops with the message.
Hardware reset
Software reset...
Hardware reset
10/11/2018 10:24:44 PM - Execution of all processes is aborted!
****************** Scan process ***********************************************
start time 10/11/2018 10:24:19 PM
finish time 10/11/2018 10:24:44 PM
I ran again and it worked but after a while it stopped.
In the old version of DATA EXTRACTOR I did not this error.
Does anyone have faults like me. And any solution to this problem ????
lcoughey
Re: I have problems with DATA EXTRACTOR V5.7 "Execution of all processes is aborted!"
Postby lcoughey » 11.10.18, 20:01
Did you submit a support request with ACE to have them help troubleshoot?
northwind
Postby northwind » 12.10.18, 07:40
This is normal, if after Hardware Reset your drive didn't come ready.
cuumaytinh
Postby cuumaytinh » 12.10.18, 12:43
northwind wrote:Source of the post This is normal, if after Hardware Reset your drive didn't come ready.
it ready after Hardreset.
Postby AJ2008 » 12.10.18, 14:43
Unless timeout settings in DE are shorter than time it takes to show ready
cuumaytinh
Postby cuumaytinh » 12.10.18, 16:39
AJ2008 wrote:Source of the post Unless timeout settings in DE are shorter than time it takes to show ready
i never saw error in old version DE. time set is same old version
Nick_TS
Postby Nick_TS » 01.11.18, 16:43
I would recommend you to install the latest version of PC-3000 and repeat these steps on a new version.
Return to “Data Extractor”
