Toshiba MK5072GSX scratched Surface
d1d
Postby d1d » 03.10.18, 21:18
I have a Toshiba 2,5" HDD whit a scratched Surface in the Center of the disk. The HDD is clicking. I have just changed the head but always the same problem. I can see the rom and ram about the com port, but i can't get the data. What i have to do?
Thanks a Lot!
Best wishes Luigi
Re: Toshiba MK5072GSX scratched Surface
Postby DataMedics » 04.10.18, 14:15
d1d wrote:Source of the post What i have to do?
Most likely just give up and move on.
d1d
Postby d1d » 06.10.18, 10:41
Also when the Surface is scratched only in the middle...? :?
See the pics...
Surface
HDD Cover
Postby AJ2008 » 08.10.18, 08:58
top surface is surface '0' and as far as I am aware you need this surface to be OK to initialize it. As most SA is stored in PCB, maybe you can place patient PCB on donor to init donor PCB, then hotswap it to your patient and try reading? Not sure this will work though but I do not think you have many options available...
Tawfeek
Postby Tawfeek » 08.10.18, 13:20
AJ2008 wrote:Source of the post top surface is surface '0' and as far as I am aware you need this surface to be OK to initialize it. As most SA is stored in PCB, maybe you can place patient PCB on donor to init donor PCB, then hotswap it to your patient and try reading? Not sure this will work though but I do not think you have many options available...
i thought the button head is the 0
Sergey_TS
Postby Sergey_TS » 09.10.18, 15:04
Tawfeek, Head0 is on the top here as was correctly mentioned above :(
AJ2008, but what about original P-list (DD)...? :?
Tawfeek
Postby Tawfeek » 09.10.18, 17:16
Sergey_TS wrote:Source of the post Tawfeek, Head0 is on the top here as was correctly mentioned above :(
Is head 0 on the top in all HDD kinds or just in Toshiba ?
Postby AJ2008 » 10.10.18, 11:18
I agree this is a problem... :?
Return to “Toshiba native”
