HN-M101MBB - bad head 0, how to disable SA copy 0?
Moderator: Garry_TS
Martin281
Postby Martin281 » 16.09.18, 21:37
Hello guys,
I have several HN-M101MBB drives and these have faulty head0, so SA copy 0 is unusable. The drives get ready but after a very long time (30+sec), because cannot read the SA copy 0. Are there any steps how to disable the SA copy 0? I have found only the way how to change the modules positions in the SA (by editing the FIT module) but this is useless - the head 0 is dead.
Re: HN-M101MBB - bad head 0, how to disable SA copy 0?
Postby AJ2008 » 17.09.18, 09:04
HDD initilization with head map edit in RAM option - all heads have SA copies, it will start OK from copy 1 if you init with map of 1,1,2,3 as an example.
Filipp_TS
Postby Filipp_TS » 25.09.18, 11:20
This article describes the procedure:
https://blog.acelab.eu.com/pc-3000- ... n-ram.html
Return to “Spin Point”
