Sony 32Gb which layout ?
CS DATA RECOVERY
Postby CS DATA RECOVERY » 08.09.18, 08:01
Can you pls tell me which layout i need to take in pc3000 solution center i guess type 2 but my card 9 pins a row .
Pavan
32 sony.jpeg (7.95 KiB) Viewed 6672 times
Regards,
PAVAN KUMAR
CS DATA RECOVERY
jerema
Re: Sony 32Gb which layout ?
Postby jerema » 08.09.18, 13:13
I think on left column : forget the last 2 pins:count from above 8
on right column: forget the first and last 2 pins: count starts from second line
alternate, when this not work I can send you an alternate pin layout
good luck
Bildschirmfoto 2018-09-08 um 14.21.23.png (66.93 KiB) Viewed 6661 times
CS DATA RECOVERY
Postby CS DATA RECOVERY » 10.09.18, 07:07
Thank you Jerema, i will try your way then update you .
Pavan.
Regards,
PAVAN KUMAR
CS DATA RECOVERY
