Bug report: Port number selection changes when I enter and exit utilities
If I enter a utility on a port 0 for example when I exit it changes to port 1. Happens on all ports when I enter and exit utilities.
Re: Bug report: Port number selection changes when I enter and exit utilities
Do you open all the ports at the same time?
Or a port at a time?
let me rephrase pclab's question. Do you open a separate instance of PC3000 for each port?
Its a bug and happens in one instance of running pc3000 express. The 4 port select drop down. When you enter the utility and exit it changes the selected port box to 1 number higher! Just a note for the developers
