h.d.d 250 bsy
sepid
h.d.d 250 bsy
Postby sepid » 13.08.18, 10:16
hi to all
i have a h.d.d 250
fw:cc49
this is hard only bsy
but my access to module and Sysfile
i do edit id, edit id do it but when power off/on change edit id not do
output terminal
F3 T>
Rst 0x08M
Servo Processor Is Reset.
ExecuteSpinRequest
F3 T>V1
User Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
0 0 0 0 0 0 0 0 0 4 0
Head 0: entries 1 slips 0
Total Entries 1 Total Slips 0
F3 T>V40
Total entries available: 0
i think not load translator
i do short pin
i do isolation
i do change PCB
but not work
sysfile 35 attach
please help
35.rar
(749 Bytes) Downloaded 298 times
Re: h.d.d 250 bsy
Postby AJ2008 » 13.08.18, 11:47
Possibly is translator issue, but you need to consider post processing defects before clearing - since sys files can read you should make full backup of all modules first
Filipp_TS
Re: h.d.d 250 bsy
Postby Filipp_TS » 13.08.18, 17:12
Double check that heads allow to write at all.
Modify 93 sys file then re-read it and check that all changes has been applied.
After that make backup of 28, 1B, 35 system files and try to regenerate translator.
sepid
Re: h.d.d 250 bsy
Postby sepid » 14.08.18, 07:16
thanks filip @ aj2008
i do repeat short pin
now h.d.d ok
very thanks
