How to read the sector again?
I read several hundred sectors from Active PC-3000 Utility before I realized that the reading is wrong. I would like to read them again normally.
Reread the sector already read
Re: Reread the sector already read
Go to Service > Clear Map then select the orange color only and clear that.
You can also probably do this through the submap option, but that's a bit more complicated.
Thank you DataMedics. It works.
I've been a fool in practicing this method long time ago. I chose the wrong key ( not JMS538S) and I couldn't fix it again. I couldn't pick the right key. I had to re-read sectors. the cost of stupidity was a waste of time.
Also, you can create a submap of reading sectors. Disable Skip options in task settings and re-read this map again.
