After swapping the heads and unlocking the ROM this is what I was getting in terminal:
Code: Select all
Tech Unlock Handshake: 0x33693C60
Reply:
Rst 0x0100MAF00550001
No HOST FIS-ReadyStatusFlags 0002A1A1
IDLE1I could work in terminal, but ATA registers stayed stuck at BSY. I tried numerous times to modify System File 93 and disable the media cache and other unnecessary functions but the changes never took no matter how many times I tried it.
Heads were re-tested back in the donor and they're 100% functional still, so I know it's not any damage to the heads.
Finally, having run out of options, I followed the Ace method here: http://blog.acelab.eu.com/pc-3000-h ... error.html
(there was one NRG entry, but I can deal with the partial access issue later)
Now after doing the translator regen (which took 7-8 min and spit out a number of errors) the ATA registers do go to DRD DSC but the drive still won't ID or allow anything to work over ATA, I can still only work in terminal. Modifying System file 93 is still not working as well. On startup the drive is spitting out a lot of MCMT errors, so I'm pretty certain the media cache is at fault here, but I can't seem to do anything about it since modifications to modules don't take.
Anyone think they know of a method to force it to write the changes?
