I have HDD WD40PURX-64NZ6Y0, family apollo.
HDD is not detecting and needs head change.
I have got Donor HDD WD40PURZ- 85TTDY0, but family is same as apollo.
When I am opening Mod 47 and the microjog editor to see whether heads are compatible or not, everything is 00 in microjog editor.
How to find a compatible head ?
Head compatability for WD40PURX
- DataMedics
Re: Head compatability for WD40PURX
I wouldn't worry much about microjogs. More important is matching the right part of the DCM, date, country.
- Amarbir[CDR-Labs]
Imnew wrote:Source of the post Hello,
can you share photos of label from both patient and donor drives
The country for both is thailand.
DCM of patient is HANNNTJMHB and date is jan 2017
DCM of Donor is HHNNHT2MHB and date is may 2018.
Sending the photo of label also.
- DataMedics
T2 and TJ DCM codes are not often cross-compatible. You might get lucky and it'll work, but not often. I'd keep looking for another donor.
Thanks a lot. I will try to look for another donor
DataMedics wrote:Source of the post T2 and TJ DCM codes are not often cross-compatible. You might get lucky and it'll work, but not often. I'd keep looking for another donor.
T2 and TJ should be ok, Tx is not compatible with Vx
AJ2008 wrote:Source of the postDataMedics wrote:Source of the post T2 and TJ DCM codes are not often cross-compatible. You might get lucky and it'll work, but not often. I'd keep looking for another donor.
I agree with this.
- DataMedics
Maybe I'm just overly picky with my donors. I just know what's always worked for me.
I guess there's only one way for the OP to find out...
