I have Seagate ST500dm009 Firmware CC43
Family 9401 Pharoad_oasis.
Terminal output
Boot 0x20M
SpinUp
Rst 0x20M Thermistor Temp 001F
Retry delay
Retry delay
DOS:0 Scan Unit
LD:
PP:
LED:0x000000EE FAddr:0x003211FC
pcb no: 100774000 REV C
I can't access terminal. After terminal port it gives immediately LED error.
Noclicking, NO motor stop.
Thanks,
Seagate Pharoah_oasis st500dm009 error LED:0x000000EE FAddr:0x003211FC
Re: Seagate Pharoah_oasis st500dm009 error LED:0x000000EE FAddr:0x003211FC
How to get terminal access T>?
I have tried with read channel short on the pcb but can't sucess.
is any alternate method to get terminal access?
thanks,
thanks,
I have attached the Images of pcb.
I have assume two point for the read channel. and tried both the points but can not success to get Terminal Port T>.
is any suggestion? How to get the T>?
Thanks,
Thanks,
Did you unlock it? If i remember corectly they have locked terminal.
SGdata wrote:Source of the post Did you unlock it? If i remember corectly they have locked terminal.
Yes I have tried with unlock also.
Generally The locked hdd gets the Terminal prompt T>. After that if you send any command it gives error like "diagnostic port is locked"
In My case I can't get the Terminal prompt T>. The LED Error coming continuously.
Check serial number inside ROM vs sticker on the drive
Doomer wrote:Source of the post Check serial number inside ROM vs sticker on the drive
checked serial numberinside rom. it is same. But the date field information does not shows year. Year field is blank.
The hdd is seagate certified repair hdd.
Well the serial port log is not really informative, so unless somebody can take this FW and check address FAddr:0x003211FC it's gonna be a guess work here.
My guess is the drive eats up something unhealthy from the SA and dies.
Doomer wrote:Source of the post Well the serial port log is not really informative, so unless somebody can take this FW and check address FAddr:0x003211FC it's gonna be a guess work here.
But How to take FW? We can not access terminal T>.
Hemendra wrote:Source of the postDoomer wrote:Source of the post Well the serial port log is not really informative, so unless somebody can take this FW and check address FAddr:0x003211FC it's gonna be a guess work here.
I meant somebody from R&D from Ace
I've got one here with the exact same issue. Changed HSA, changed PCB, and it's still the same thing.
I can get terminal for a split second and even managed to switch to level 7 and send the sleep command a couple times, but then it just returns a different LED error. LED:0x000000BD FAddr:0x00007C1D
instead of the usual LED:0x000000EE FAddr:0x003211FC
Regardless, I can't see a way to fix it with no terminal or SA access of any kind. But, I'm open to ideas if anyone has one.
DataMedics wrote:Source of the post I've got one here with the exact same issue. Changed HSA, changed PCB, and it's still the same thing.
did you manage to solve this
- vonguyencompany
You can try hot swap solution on seagate hard drive
Data recovery service in Vietnam
24/16 Doan Thi Diem Street, Phu Nhuan District, Ho Chi Minh City, Viet Nam
Phone: 0888 711775 - 0974 756775
Details: https://cuudulieu24h.com/bang-gia-cuu-du-lieu.html
