This is my fist post i'm new with data recovery
how to select the right sata PCB compatible with that one USB
i have this usb hard drive :WD10JMVW-11AJGS2 PCB: 2060-771961-001
To find the right PCB what I have look at is..
I am new at the word of data recovery
i bought pc-3000 express with ssd
one more question when i recieve a hard drive how do i know that i need to change a pcb or head or do i need to do a clean room
thank you very much in advance for any hint or advice.
if anyone could give me a class they can contact me.
How to select sata PCB compatible with the one USB PCB 2060-771961-001
- tonoarimany2012
- DataMedics
Re: How to select sata PCB compatible with the one USB PCB 2060-771961-001
I keep a running list of cross compatible WD USB/SATA PCBs on this thread: https://www.data-medics.com/forum/wd-us ... e-t13.html
This question is probably the equivalent of asking "how do I practice being a doctor?". There's no one or two sentence answer to that question, it takes years of research and learning. You should start by reading everything you can find on all the forums until it all starts to make sense to you.
tonoarimany2012 wrote:Source of the post ne more question when i recieve a hard drive how do i know that i need to change a pcb or head or do i need to do a clean room
- Amarbir[CDR-Labs]
Hello ,
To select a Compatiable data board you have to make sure Main MCU and Motor Controller Have Same Numbers .Then You Can Swap Main MCU Rom To SATA Board Or Use Acelab PC 3000 To Read USB Board Main MCU Rom And Write To SATA Board .You Can Also Manually Wire a USB Board To SATA By Tapping Rx And Tx Lines Going From Main MCU To USB Controller
tonoarimany2012, http://blog.acelab.eu.com/if-you-ar ... rives.html
