Is it possible to repair a task in DE?
Today it turned out that both task.prm and task.bak files are damaged (empty).
The rest of the files looks correct.
For example, can you create a new task but import the already read data from the old task?
Task file repair
Re: Task file repair
Preserve original files in case you need to get support from Ace.
You can create a new task > exit DE > copy map.bin from failed task > open the new task > select map tab if not on it > right click in map and choose recalc.
It worked but unfortunately not quite.
When you try to scan mft + index everything loses in lost and found.
Previously, there was a nice directory structure.
Maybe something more was damaged.
Nevertheless, thank you for your help.
Did you change PC-3000 version when re-open the task?
No, I didn't.
