BUSY HD082GJ
Moderator: Garry_TS
shahi
BUSY HD082GJ
Postby shahi » 05.04.18, 14:48
Can't go to ENG>
What can be the issue?
SPW 3.0G LinkOk!5V: 04982
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0006
DAC: 8E8F
SK C: 0001868A
ENG>SRV>
SvoTbl Loaded
CL 000F CM 0028 SL FF60 SM FF81
BD
FdtTbl Loaded
*** Break at 0x000C [from Trap]
000C: FFFF
DBG>DBG>
Filipp_TS
Re: BUSY HD082GJ
Postby Filipp_TS » 06.04.18, 14:21
It can be problem with firmware or with heads/surface.
Check in database is there compatible BURN resources and try to use them, otherwise try to perform hotswap procedure.
Return to “Spin Point”
