Self Encryption Device (SED) Problem
betty
Postby betty » 31.03.18, 11:46
I have 2tb WD Usb Hdd and i convert it to SATA ... Now its working with Error SED .. I followed the following thread "http://blog.acelab.eu.com/pc-3000-hdd-how-to-solve-sed-problem-in-25-wd-drives.html ".. after that everything OK.. But When i trying to recover the data i can't get any data from the hdd. But when we check the Sector view , i can see the data in there .
Also one more thing " the customer told me that he was used the password for opening the hdd by the utility of WD. unfortunately, the Drive was formatted.
I remove the SED from Hdd Edit ID . Even I am not able to get any Data.
Any one have face the same experience, please help...
betty
Blizzard
Re: Self Encryption Device (SED) Problem
Postby Blizzard » 31.03.18, 21:53
Did you forget to check decryption in Data Extractor settings? You need to choose the same decryption option that gave you data access in the utility. After you resolve the issue, don't forget to clear map for any sectors that were read without decryption.
betty
Postby betty » 02.04.18, 07:52
No Blizzard, that option I already selected.Even though i am not able to get any kind of data from the HDD.
Postby AJ2008 » 03.04.18, 09:29
betty wrote:Source of the post the customer told me that he was used the password for opening the hdd by the utility of WD. unfortunately, the Drive was formatted.
Probably it was a Cryptographic erasure
Maxim_TS
Postby Maxim_TS » 19.04.18, 18:12
betty wrote:Source of the post he was used the password for opening the hdd by the utility of WD
If it was WD Smartware, it was necessary to use this software for decryption, but I'm afrain AJ2008 is right as always: after a few wrong retries the data was formatted...
betty
Postby betty » 20.04.18, 06:40
thanks maxim,
i was not able to recover the data.... so that hdd was given back to the customer....
while he(customer) using the hdd, suddenly the hdd asking for the Formatting . and customer has done the format.that is story .
any way next time i wl try ...
betty
Return to “WD USB”
