Rom busy
prashantasus
Rom busy
Postby prashantasus » 10.02.18, 04:40
Diablo3s
Drive busy
If isloate then busy
If kernal mode then read rom read rom modules but do not allow sa block
Pls tell me how its possible to busy stop
Re: Rom busy
Postby AJ2008 » 12.02.18, 10:31
Short tv9 + tv10 then power and wait until DSC DRD status is present
Maxim_TS
Re: Rom busy
Postby Maxim_TS » 12.02.18, 17:05
prashantasus wrote:Source of the post read rom read rom modules but do not allow sa block
Block module 30 access in ROM, restart the drive and upload Dir and loader into RAM, then solve Slow Responding.
Re: Rom busy
Postby Amarbir[CDR-Labs] » 25.02.18, 09:50
Maxim_TS wrote:Source of the post
Question ,
On what drives do you want us to block module 30 and why .Why does general blocking not work in these drives
Maxim_TS
Re: Rom busy
Postby Maxim_TS » 26.02.18, 17:00
prashantasus, have you tried something already?
prashantasus
Re: Rom busy
Postby prashantasus » 12.03.18, 08:11
Hello sir busy busy busy rom and last goto amnf
Sir how to access sa in hotswap and other idea ?
Maxim_TS
Re: Rom busy
Postby Maxim_TS » 14.03.18, 15:49
prashantasus wrote:Source of the post busy busy busy rom and last goto amnf
It looks like head issue. What in log after utility start? All ROM modules are good?
prashantasus
Re: Rom busy
Postby prashantasus » 15.03.18, 04:17
Rom modules are good.
After 2-3 minutes goto amnf.
Motor ic heat.
Only PCB attach drd DSC ready
Any idea sa access in hotswap
Maxim_TS
Re: Rom busy
Postby Maxim_TS » 15.03.18, 14:26
prashantasus wrote:Source of the post Any idea sa access in hotswap
Hot-swap doesn't work for this drive family usually.
In February I wrote to block module 30 access in ROM, then restart the drive and upload Dir and loader into RAM.
Have you tried it? What was the result?
