The drivd arrived with HSA issue.
Swapped and GOT ID
But data area full of UNC;BAD SECTORS.
SOLVED 32 ISSUE AS IT WAS FOUND BAD. Still inaccessible data area.
All critical module looks fine
Any advice would be highly appreciated
WD10EZEX FULL OF BAD SECTORS (STRANGE)
- digitalsupport
- User
Re: WD10EZEX FULL OF BAD SECTORS (STRANGE)
Can you access any LBA at all?
What is the outcome of a head test?
Are heads still working ok in donor drive?
Used 3 DONOR so far, all with same symptom
Yes, the HEAD is working fine while taken back
The HEADS are working fine without issue.
According to ACE TS - there is an "unknown error code 4593"
