WD1JMVW
emir_has
WD1JMVW
Postby emir_has » 22.02.18, 08:01
I have this drive as patient and it has head isssue. So I swap heads with donor which is almost identical (3 month difference, DCM same). I it is USB drive so also i found SATA compatible board. This compatible board is ok tested on working drive it is ok.
So i swap heads but when i want to transfer microjogs from donor wd utility doesnt show any values (only zeros). So can somene tell me is it bug or it is normal for these drives??
If it is normal is there any other adaptives which i have to transfer from donor?
Why then hdd doesnt initialize normal with donor heads???
Thank you guys!
Maxim_TS
Re: WD1JMVW
Postby Maxim_TS » 22.02.18, 14:09
The Microjogs in these drives are in different place, that's why we can't edit them and can't build the head map in RAM.
Most possibly the donor was not compatible, and you need to look for new heads.
emir_has
Re: WD1JMVW
Postby emir_has » 22.02.18, 14:51
Thank you
emir_has
Re: WD1JMVW
Postby emir_has » 22.02.18, 15:18
Can you tell me where are microjogs for these drives in wihich module and can I read it with hexeditor and marwell plugin???
Re: WD1JMVW
Postby Amarbir[CDR-Labs] » 25.02.18, 08:23
Maxim_TS wrote:Source of the post Hello
Question ,
We can see preamp but not micro jog in this .I have never seen a issue with micro jogs in this .I have a question for you when you guys know its at a different place can you guys not update too to find and average those or its a non researched issue
Re: WD1JMVW
Postby Amarbir[CDR-Labs] » 25.02.18, 08:25
emir_has wrote:Source of the post Hi
Thank you guys!
I think you were the one asking me thin on a chat or something ,Can you tell me whats the issue in details .It will be great if you could share patient and donor roms with me here and also post a picture of both
emir_has
Re: WD1JMVW
Postby emir_has » 25.02.18, 13:09
Here is the pation sticker https://imgur.com/NsBiHS3
Here is the donor sticker https://imgur.com/N24JqjZ
Donor worked 100% I put compatible SAT borad SED decrypted and backup all system info.
Patien backuped ROM and ROM module no access to SA.
Here is the microjogs editor: https://imgur.com/aFhK18e
emir_has
Re: WD1JMVW
Postby emir_has » 25.02.18, 13:12
Here is ROM patient: http://ul.to/nwqohbcd
Here is ROM donor: http://ul.to/1b093ppw
