FBLITE MICROJOG AND DAC VALUES
SLAB_TEAM0
Postby SLAB_TEAM0 » 04.12.17, 12:37
Techno mode key
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Modules directory address............... : 153 477
ROM Modules:
ROM version............................. : 16.7CG
ROM F/W version......................... : 0016007C
Overlay F/W version..................... : 16.7CG
Servo F/W version....................... : N0.41
Service area:
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActSpeed
SA dir reading (ABA/CHS)................ : Module reading error: ABA 153 477(1) reading error Physical read error C/H/S: -150/0/1156 Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST"
Configuration reading................... : Module ID 02 reading error Data request error Device Error Detected: "Unknown error code: 3746"
Hi Sirs,
this log refers to a WD10JPCX-24UE4T0
Concerning to heads swap compatibility parameters and specifically to microjog analisys, microjog values, taken via Work with ROM>View ROM Information , shows "0" for all heads
Using ACE hexEdit Marvel plugin parser, the output is completely different with values that seems to be randomized and unreal.
Same results are obtained backuping SA from a working drive from the same family: microjog values all set to "0"
How should we approach such a cases? 0 is a real microjog value or ACE tool in FBLIte family is not able to correctly parse 47 module dump to extract microjog?
Besides microjog, using ACE hexEdit Marvel plugin, I see DAC values for each of four heads. No info are provided in the manual and in the blog. What is their function? Are they important compatibility params for head change?
Thank you in advance for your answers
Re: FBLITE MICROJOG AND DAC VALUES
Postby Amarbir[CDR-Labs] » 04.12.17, 16:14
Well,
I am Also interested to know the same
emir_has
Postby emir_has » 18.02.18, 18:51
Me too curently I have one patient and donor and both shows 0 in microjog editor.
Maxim_TS
Postby Maxim_TS » 20.02.18, 11:37
emir_has wrote:Source of the post in microjog editor.
ACE developers are working on this issue, please wait for solution.
emir_has
Postby emir_has » 20.02.18, 20:22
Is there any workoround for this problem??? I have one customer and time is question!
SLAB_TEAM0
Postby SLAB_TEAM0 » 16.05.19, 16:29
Maxim_TS wrote:Source of the post
Sorry if I resume this old post of mine.
Maxim_TS have you solved this issue in new software versions? Or anyway have you found a way to help us in donor research for these drives?
Thank you for any help.
Maxim_TS
Postby Maxim_TS » 28.05.19, 12:34
SLAB_TEAM0, Microjog editing is still not possible for FBLite drives.
