Turning off windows update in windows 10
osity
Postby osity » 07.02.18, 23:40
is there a way to do this for Windows 10 Pro other than disabling the Windows update service?
I was rebuilding an image on a flash drive and it seems to have restarted after 7 hours. Pretty frustrating.
lka124
Re: Turning off windows update in windows 10
Postby lka124 » 08.02.18, 07:19
I use since several time "RebootBlockerSetup" Download at chip.de and works so far reliable
MasterT
Postby MasterT » 08.02.18, 13:25
You can do it with a bat file and some commands to stop key services in windows.
I had the same problem and this is the solution i came up with.
I attached an archive with 2 file one for enable and one for disable Windows Update completely.
Right click and Run as Administrator.
Good luck.
WU.rar
(255 Bytes) Downloaded 496 times
LarrySabo
Postby LarrySabo » 08.02.18, 14:48
Or try Windows Update Blocker: https://www.sordum.org/9470/windows-update-blocker-v1-0
Be sure to check "Protect Service Settings."
osity
Postby osity » 12.02.18, 20:26
Thanks i'll try the windows update blocker... seems pretty a tad easier than disabling the service manually.
Return to “PC-3000 Flash”
