Postby AJ2008 » 10.01.18, 09:33
Use bitview to check if structures look good.
run RAW recovery to check for files - if none are found, apply inversion then try again - as this is 4GB it may be old and not with XOR. If no files are found in RAW with and without invert, then it will be some XOR. If Xor analysis finds no results then maybe you have older software with old XOR database or PC3000 cannot support it. do you have photo of the card (map side)?
