Microsoft Surface Pro 4 SSD
Hello, I was given a ssd extracted from a surface pro. It is not recognizable in an m.2 adapter. Can a chip off be done on this ssd? Any suggestions on how to proceed? Thanks, Dave
Re: Microsoft Surface Pro 4 SSD
Hello Dave. Do you have any pictures with your SSD drive? We need SSD model name and controller name.
Hi Roman, It’s a Samsung model mz-flv2560, p/n me flv256hchp-00mv. Thanks, Dave
Hi Roman, I've just attached the picture. Thanks Again...
this will be encrypted so chip off is not possible. I also this this is 850 EVO family so there is very little that you will be able to do at the moment - maybe roman has some ideas on it?
This is PCI-E PM951 - right now it's impossible to recover this drive with PC-3000. Probably later in this year we will find the way.
I guess no update on this yet?
Have one that PC3K portable will auto detect that it's NVME, but will not ID..
"NVMe Identify reading error: NVMe Identify reading error (CNS: 0x01; NSID: 0);
Request status.......................... : 06 [Command sending timeout]"
By default, all working NVMe drives should be detectable on Portable III, but if you can't get ID, means that there is a problem with Firmware.
Samsung drives with damaged Firmware can't be recovered by now. They all protected with digital signature.
