I had HDD DT01ACA050 MS1OA8A0.
This HDD recognized PC3000.
capacity size and sectors is very good.
I could read succeed modulus and SA.
but I can't read data area.
I tryed changed RDMT, PSHD and "Initialize Translator in RAM".
Could you some adviced for me?.
DT01ACA050 MS1OA8A0
Re: DT01ACA050 MS1OA8A0
gmdata, did you check SA modules? You can attach log here, I will take a look
- DataMedics
gmdata wrote:Source of the post I tryed changed RDMT, PSHD
What exactly do you mean by "changed RDMT, PSHD"?
Thank you. Sergey_TS and Data medics.
I send log data. I think that modules is good.
I tryed to write RDMD, PSHD from Another HDD' RDMT, PSHD.
But HDD was same. Can't read Data area.
gmdata, SA looks OK here.
It was a bad idea, because these modules are unique for every drive. Hope you backuped them.
Please write them back!
Please check if all critical modules were uploaded into RAM (Sercvice Objects --> RAM)
Is your drive with single head
gmdata wrote:Source of the post I tryed to write RDMD, PSHD from Another HDD' RDMT, PSHD
- Amarbir[CDR-Labs]
Sergey ,
This Drive is Single Head IMHO
Thank you. Sergey_TS and Amrbir.
The backed up file was written to the original HDD.
The head has one. I confirmed it on PC3000.
gmdata, Most probably it's head degradation in your case, but did you check content of RAM as I mentioned before?
How do you check the data in RAM?
This hard is a firmware 8A0,
It is difficult.
Please let me know how to check the head ... Thank you.
It is difficult.
