I have two same hdd case. Drive model is HITACHI HDS721050CLA362. When I run special utility I see following screen:
Techno mode key..........................................: Ok
Loading modules table..........................................: Ok
Loading the table of "open" modules................................:Ok
Error executing command: ROM ?????? ??????? ??? (0x200, 0x40)
Device error detected ()
Error reading NV-RAM: Drive not ready
NV-RAM is not loaded
Can anybody tell me some clues about this problem and what sould I do?
HITACHI NV-RAM ERROR
Re: HITACHI NV-RAM ERROR
just finished a recovery of the same drive model (dropped / heads swapped) and it had the same error reading NVRAM when entering utility. It loads modules, tries to read NVRAM, clicked and goes bsy. I just power-cycled the drive and went to NVRAM-edit, made no changes and pressed ok. After that I get ID and could test modules, all were fine but some critical were not loaded to RAM. So I did that from backed up files. After that I had access to userdata and could image most of the drive. On parts with media damage the drive went bsy and I had to do it again(power-cycle, nvram edit, load modules to ram). I read the remaining 2 GB by hiticha-utility.
Try it & good luck.
Try it & good luck.
Seems Like a Pc3K Bug Then
kenanyasar, pcn, Guys, this model is not related to M24 Architecture
The problem has been already discussed here viewtopic.php?f=161&t=9373
