W.D Passport
paweliusz
Re: W.D Passport
Postby paweliusz » 03.11.17, 14:59
Hello I have USB PCB 2060-800069-001 can I transfer chip to SATA PCB and what model I can use?
paweliusz
Re: W.D Passport
Postby paweliusz » 16.11.17, 15:15
Any advice
msurgeon
Re: W.D Passport
Postby msurgeon » 16.11.17, 16:02
At this point it would be easier to solder a SATA connector to the board and stop hunting for the compatible PCB.
Re: W.D Passport
Postby DataMedics » 16.11.17, 18:38
paweliusz wrote:Source of the post Any advice
If I had to guess, I'd suspect it's a 2060-800052-000 board you want, since it looks identical to the newer wd10spzx SATA drives...but I've never tried it and I could be wrong.
hddr49
Re: W.D Passport
Postby hddr49 » 30.11.17, 15:58
Thanks guys !
Because of this thread, today for the first time I put Heads from donnor WD5000BPVT-22HXZT1 to Patient WD5000BMVW-11AMCS2 (both zephir) and it worked like a charm !
Return to “WD USB”
