PC3000 installed, but status register lights do not show
The green power status light works, but the register lights do not come on...
- DataMedics
Re: PC3000 installed, but status register lights do not show
Do you have a confirmed good drive attached to the channel?
Drives are good..
Did you connect Power cable to the board?
Sistrum Data Recovery
http://Www.datarecovery.mk
Is it possible you are on channel1 but you have channel0 power connected to the drive? Have you checked the connections at the PCIe card?
Try changing PCIe slot, and checking the cable connections, also reverse the sata cables.
