I noticed a strange problem with my PC3000 UDMA card.
When I connect 1 disc to channel 0 or 1 everything is fine. Hdd stars up and gets readiness.
However, while on channel 0 will turn on the power of the drive, the hdd on channel 1 does not turn on.
Only BSY and PHY lights are on. Every few seconds they blink.
What's the problem?
Not enough power for two hdd?
Re: Not enough power on two hdd?
Upgrade your PC power supply.
In my opinion, the PC power supply is enough power. Earlier everything was fine.
Not necessarily a more powerful supply, but a better quality one or just a different one. We had a similar problem when we upgraded to the new UDMA card a while back and the better PS solved the problem. It's certainly worth trying.
There are 3 HDDs. I'll try turn 2 drives off tommororow. I'll see if reduction power consumption resolve problem.
Re: Not enough power for two hdd?
Today I disconnected all 3 hdd. I left only the system ssd. Unfortunately nothing has changed.
The power supply is 960 Watts (Dell Precision Workstation). Nothing wrong with the computer does not happen, which could indicate power problems.
I have observed that the problem occurs even when I turn on the power of the second channel even without a connected drive.
Another disturbing symptom is that the 3.5 WD5000AAVS drive doesn't start up on my PC3k card. While connected to a normal computer, it starts up normally.
EDIT:
Problem solved
It turned out that the reason was to connect to the same power line of the additional USB 3 controller.
Once it's disconnected everything is fine.
EDIT:
Problem solved
Glad you figured it out but you never did change power supplies to see if that would have solved the problem even with the USB3 connected.
