I'm running into an issue with a ST2000LM007-1R8174, was able to unlock the SA and clone the first 50M sectors. Then the drive started to error, discovered that the translator was corrupted, attempted a "Recover Translator". It was only able to get to 50M. Tried the Single LBA Adjustment and it produced the Err: 0x9. After that I get the same error if I attempt to use the "Recovery Translator" method. Any ideas what may be causing this?
Thanks for any help, thrilled about the new update!
Rosewood_A5 / Error: Translator regeneration error! Err: 0x9
- Masterclass
Re: Rosewood_A5 / Error: Translator regeneration error! Err: 0x9
Did you backup sysfiles before translator regen?
Yes, I attempted to write 28 back, but receive an Unsupported FW message when I try to write it.
- Masterclass
Its because write sysfiles is not implemented in FW of such disks
tdrc wrote:Source of the post Yes, I attempted to write 28 back, but receive an Unsupported FW message when I try to write it.
You can write a system file via ATA indirect mode when you have the drive in ready state.
Dmitriy_TS wrote:Source of the posttdrc wrote:Source of the post Yes, I attempted to write 28 back, but receive an Unsupported FW message when I try to write it.
Dimitry,
Can You Explain Difference Between Direct ATA And Indirect ATA Mode ?
Dear Amarbir,
ATA direct mode uses three parameters to access the system file such as:
1. Volume
2. File ID
3. Copy
ATA indirect mode operates with more parameters and it is useful for some families: Wyatt, Brinks, Rosewood etc.
Amarbir[CDR-Labs] wrote:Source of the post Can You Explain Difference Between Direct ATA And Indirect ATA Mode ?
1. Volume
2. File ID
3. Copy
Having problem where none of the system write methods work. "Terminal" method thinks it worked but doesn't "stick." ATA (direct) and ATA (indirect) just cause drive to go from ready to busy. Thoughts?
Hello AceLabs Support
I think it would be a really good idea for your next blog post to publish a typical step-by-step diagnostic test and commands for Rosewood drives. These disks are difficult to work on, and I have found that donor heads can be unstable and fail in a short period. Powering the HDD off and on multiple times should be avoided. It would be useful to know the best method to assess these.
Thanks.
Thanks.
Dmitriy_TS wrote:Source of the post Dear Amarbir,Amarbir[CDR-Labs] wrote:Source of the post Can You Explain Difference Between Direct ATA And Indirect ATA Mode ?
1. Volume
2. File ID
3. Copy
Well ,
Understood This But Whats The Difference ?
Dear Amarbir,
For the drives where system files are read via ATA direct mode, you can read system file by typing volume, file id and copy of the file in the top sys files tab.
For the drives where system files are read via ATA indirect mode, you have to upload module and system files table in the utility and then check the box of the system file in the sys file tab to read file. You have to follow this procedure because of ATA indirect mode requires mode parameters (Volume, FileID, Copy and other). When you check the box you lay down system file parameters automatically.
Amarbir[CDR-Labs] wrote:Source of the post Well ,
Thank You Boss
FAIL Servo Op=0395 Resp=0007
FAIL Servo Op=00DF Resp=0007
00DF 0000 0001 0005 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 2B35 2799 0000 0002 0000 BA27 000C FFB2 0000 0001 0000 0000 0000 0000 0000 E600 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0003
FAIL Servo Op=0095 Resp=0007
0095 668E 0004 7FFF 7FFF 7FFF 0000 0003 0000 0000 8000 0000 FFFF 0000 0000 0000 0000 0000 0000 0000 0000 61B0 450F A000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 0002 0001 FFFF 9BAC 0000 BA27 000C FFB2 0000 0001 0000 0000 0000 0000 0000 E600 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2032
ResponseFrame 0002 0001 FFFF 865A 0000 BA27 000C FFB2 0000 0001 0000 0000 0000 0000 0000 E600 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2032
ResponseFrame 0002 0001 FFFF D561 0000 BA27 000C FFB2 0000 0001 0000 0000 0000 0000 0000 E600 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2032
Low Current Spin
FAIL Servo Op=0100 Resp=0007
0100 0001 0000 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1900 0000 0C21 0D40 0008 0000 0000 0000 0CF7 0001 0000 0000 0000 0000 0000 E600 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0003 Loop=2032
Motor startedHeads loaded
ResponseFrame 0002 0010 0000 E746 0000 B6D7 000B FFAF 0000 0001 00FE 0000 0000 0000 0000 E600 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2032
Heads loaded
Boot 0x80M
Low Current Spin
FAIL Servo Op=0100 Resp=0003
ResponseFrame 18C0 0000 0C21 0A80 0008 0000 0000 0000 0D59 0000 0000 0000 0000 0000 0000 E600 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0003 Loop=007F
ResponseFrame 29D5 280A FFFD 0001 0000 B710 000C FFAF 0000 0001 0000 0000 0000 0000 0000 E600 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0003
ResponseFrame 0002 0001 FFFF FF96 0000 B710 000C FFAF 0000 0001 0000 0000 0000 0000 0000 E600 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF Loop=2032
This Type Error : Head And Track Problem One ReplaceMent Completed After Error this Any Solution ???????
Low Current Spin
Heads loaded
Boot 0x80M
Low Current Spin
Best regards,
Vijayan MBA
Raminfotech Data Recovery
call 7092114411/22
sky:raminfotech.vijayan
whatup:9841983643 / 46
Vijayan MBA
call 7092114411/22
No other solutions for such drives except Heads/surface checking.
There are a little chance that it's PCB's issue but it's approx 5% cases with such terminal error message.
Filipp_TS wrote:Source of the post No other solutions for such drives except Heads/surface checking.
Well Filipp ,
PCB issue should not be a concern of any Data recovery engineer with PC 3000 Tools ,There is No Big Deal To Read Patient ROM And Transfer This To Donor Rom And Tryout
